Part Number: TFP410
Hello everyone,
we are trying to grab a parallel RGB666 signal from one of our devices for serial testing purposes.
Our thought process was to use the TFP410 to convert this TTL Signal to HDMI and go from there.
The problem is that our small LCD fed by the RGB signal has no need for H-Sync and V-Sync as we sync its data per dataenable signal alone.
The respective sync pins are also used otherwise.
Now we are struggling to find a way to convert RGB666 to HDMI (or any other display interface) with no sync signal.
Is there a way to use the TFP410 or similar chips without the direct input of H-Sync and V-Sync from the source?
Thank you in advance,
Valentin Bischof
