Part Number: TCA9617A
Other Parts Discussed in Thread: TCA9803, TCA9617B
We have one of these buffers to drive external peripherals off-board.
The A side is connected to the CPU and is running at 3.3V. The B side supply is currently 0V (off), so we are confused why the SDA pin is pulled/driven low (SCL pin is ok)
We have a 10K pull-up on the pcb - which as its a low power design and compact works well (works perfectly when buffer is removed from pcb)
Any ideas ?
