Part Number: LMH0397
Greetings,
Please review this schematic and let us know your comments:
Best Regards, Gizem
Greetings,
Best Regards, Gizem
Hi Gizem,
Thank you for sending. I reviewed with my team and concluded that the schematic does not have any critical issues. Here are a few comments.
Nick
Hi Nasser,
Thank you for your feedback. I will proceed to the layout stage, but I need an 8-layer stack up, can you help me? Do you have a stack up file for this kind of work or do you also use the LMH0397 material? Or what should I pay attention to when preparing the stack up? The recommended path thickness on the datasheet and eval board seems to be 10mil, can I draw a thinner path than this value?
Best Regards, Gizem
Hi Gizem,
Please contact your PCB manufacturer. The stack up should support a 75-ohm single ended trace and a 100-ohm differential trace. This is typically done with a layer 2 ground plane for the 100-ohm differential and a layer 3 ground plane for the single ended 75-ohm trace.
Nick
