Part Number: DP83867IR
The datasheet page 14 states ESD Rating : Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001 MDI 8kV tested per IEC61000-4-2.
Could you please clarify
1) Is the chip protected to IEC61000-4-2 in particular withstanding 8KV at 30A I peak air / contact discharge)?
2) Does internal ESD protection of the chip eliminate the need of using external ESD protection needed for Ethernet port assuming 8kV as maximum voltage spikes expected?
Sebastian
