Part Number: THVD1420
We purchased the parts of THVD1420DRLR from TI Store, and we found that there is vinyl on the pin, pls help suggest the reason for that.
And pls suggest whether that affacts usage.
Gloria
Gloria
Hi Gloria,
If there is vinyl on the pins and you bought from the TI store I would pursue a return https://www.ti.com/support-quality/additional-information/customer-returns.html as while the device itself could be functional the vinyl on the pins could increase current density on the exposed metal increasing the contact resistance - so it could cause a degradation in performance -and cleaning the pins could induce mechanical damage depending on the strength needed to remove the vinyl. Due to those reasons I would purse the link above as this does seem to be either a packaging issue or a mechanical compliance issue so it should be a straight forward process.
Parker Dodson
Hello Parker,
What is the reason for vinyl on the pin? and100% of the mparts we receive are like this, is that normal?
pls help to check.
Gloria.
Hi Gloria,
I am not sure why it is there and I don't believe its normal - please go to the link I posted in my first reply as that will lead you to the most effective help for this situation.
Parker Dodson
