DS90LV804: How to temporarily set the output of OUTx+/- to 0V
Part Number: DS90LV804
Hi experts,
Is there a way to use the EN pin to force both OUTx+/- outputs to 0V? 0V difference between OUT+/- is not sufficient, both OUT+ and OUT- must be 0V.
Since the datasheet says that OUT+/- are in TRI-STATE when the Enable pin is LOW, I think "OUTx+/- outputs to 0V" can be achieved by adding a pull-down resistor. Could you please give me your opinion / answer?
Thank you for your help.
Taito Takemura
