Part Number: DS90UB926Q-Q1
Hello Team,
In Deserializer, I am not receiving RGB lines signals. Only Backlight is visible in display.
All the design is made as per the datasheet.
Any solution for this?
Hello Team,
Hi Vijay,
Could you please give us more info about your system:
- which serializer are you paring this with? Do you have LOCK between these devices? And can you do I2C reads from both devices?
- how are you testing the RGB lines?
- are you running end-to-end video through SER to DES in your setup while testing this?
- please try deserializer PatGen with internal clock with your display panel timings?
Ikram
