Part Number: DS250DF230
The customer has configured the Retimed and Raw outputs to switch depending on the input data rate.
At this time, is there a register to check whether the output data is Retimed output or Raw output?
Nishie
Nishie
Hi Nishie-san,
If the input data is a data rate that the retimer is not configured to lock to, the customer could check for CDR lock. Lack of CDR lock would imply that data is passing through the retimer using the CDR bypass signal chain.
Drew
