Part Number: DP83848J
Hello all,
I am currently working with the STM32H7 microcontroller in my project and have connected the Ethernet PHY DP83848 via MII. Unfortunately, I made a mistake when creating the schematic and layout, which caused the ETH_TX0 and ETH_TX1 pins to be swapped. This is obviously a problem as the connection is not correct.
Unfortunately di design is very complex and I have no way to swap the pins manually and wanted to ask heir if maybe someone here has an idea to solve this problem, would be very happy if you could suggest me a good idea,
Thank you in advance for your support!
With kind regards,
Thomas
