DP83867IS: Output of LED_2 at low temperature.
Guru 11265 points
Part Number: DP83867IS
Hi team,
When started up at low temperature, the output of LED_2 is inverted.
Started up at room temperature and then cooled down, LED_2 is normal output.
Could you give me any advice about this phenomenon?
BR.
Kengo.
  • Hi Kengo,
    May I ask what is the temperature you are testing when you see the behavior?
    What is the setup you are seeing this behavior?
    • What is the link partner?
    • Are you able to see a link up a low temperature?
    • What is the LED_2 functionality?
    • If possible, could you also try to configure LED_2 to link status functionality and see if you are able to observe the similar behavior?
    If possible, could you send us the schematic around LED_2 for us to take a look at?
    Thank you,
    Hillman Lin
