Part Number: LMH0074
Hi team,
If the use case is not using carrier detect function, in other words, always ENabled. How customer set MUTEref pin? Should it be left floating?
Hayashi
Hi team,
Hayashi
Hi Nasser,
What will happen when setting tied to GND? Is there no equalization whenever the length is?
Hayashi
Hi Hayashi,
Actually by increasing MUTEref voltage cable length gets reduced. So for example at maximum voltage on MUTEref cable reach is at the shortest length ~ 2m B1694A.
Regards, Nasser
HI Nasser,
Sorry I don't understand well. Could you explain how LMH0074 operates with MUTEref = 0V?
hayashi
Hi Hayashi,
MUTEref = 0V is not allowed. This is not valid. MUTEref voltage is between 1.6 to 2.9V.
Regards, Nasser
