Part Number: DS110DF410
Does the DS110F410 support bypass mode?
Is the bypass mode is relevant to all the features of DS110F410 (EQ,CDR'DFE'CTLE)?
Thank you,
Enav
Thank you,
Enav
Hi Enav,
Yes DS110DF410 has a CDR bypass mode. It can be used by overriding the output multiplexer and choosing the "Raw Data" option. In this mode, the signal will still pass through the CTLE and DFE blocks but will bypass the CDR block. You can read more about Raw Data mode in the section 8.5.10 of the datasheet, "Overriding the Output Multiplexer."
Lucas
