Part Number: TUSB6250
Looking for firmware that supports UltraDMA-4
Connect a Compact FLASH card to TUSB6250 with a 40pin IDE connector and use it in True-IDE mode.
Is firmware available for TUSB6250 that supports Ultra-DMA mode4?
We will review this question internally and then provide our response.
David
Hi Noboru,
Yes, there is. It is available on the product page under software development. It is called "SLLC444 — CompactFlash Firmware". Are you having any issues getting it to work? TUSB6250 data sheet, product information and support | TI.com
As you have said, section 13.5.1 of the datasheet states our CompactFlash firmware supports True-IDE mode. "CompactFlash storage cards are required to support all three types of interface protocols". Those are PC card memory mode, PC card I/O mode, and True-IDE mode.
According to section 2.3 of the datasheet the ATA/ATPI controller is a "High-performance DMA engine supports all PIO, multiword DMA, and UDMA transfer modes up to UDMA mode 4 (UDMA-66 or ATA-66)"
Let me know if you have any questions.
Nicholaus
Mr. Nicolaus
Thank you for contacting us.
I'm trying it right away.
Regards, Shimizu
Sounds good. Let me know if you need any more assistance.
Nicholaus
Please make note of section 13.4.2.3 in the datasheet:
"To ensure correct functionality, better signal integrity is desired for faster ultra-DMA modes. The optional 80-conductor cable assembly is specified for use with the original 40 connectors. Use of this cable assembly is mandatory for systems operating at ultra-DMA modes greater than 2"
Hi Noboru,
Let me know if there has been any updates here.
Nicholaus
