Part Number: TUSB9261
Hi, team:
Could you help check the USB_VBUS limited value?
I noticed in Q version it describes as follow:
Does it means the USB_VBUS VIH limited is 0.4V ?(The signal USB_VBUS must be connected to VBUS USB_VBUS 50 I through a 90.9 kΩ ±1% resistor, and to signal ground through a 10 kΩ ±1% resistor.)
And I hope to know what will happen if USB_VBUS is lower than the VIH limited?
Hope to get your reply, thanks.
