Part Number: DP83867E
Hi Team,
I have questions about how to connect DP83867 to RJ-45.
The datasheet(P.104, Figure 9-2) and EVM users guide(P.12-13, Figure 5, Figure 6) have different how to connect, is it okay to use either one?
Positive and negative are swapped on all differential lines.
Specifically, it is as follows.
Please also see attached.
The customer have executed 1000BASE-T compliance test at both of their board designed based on the data sheet and EVM, but they are confused because the result is different.
Please let me know if you have any advice.
<DP83867 to RJ-45: data sheet>
TD_P_A to Pin 1
TD_M_A to Pin 2
TD_P_B to Pin 3
TD_M_B to Pin 6
TD_P_C to Pin 4
TD_M_C to Pin 5
TD_P_D to Pin 7
TD_M_D to Pin 8
Data sheet:
https://www.ti.com/lit/ds/symlink/dp83867e.pdf
<DP83867 to RJ-45: EVM users guide>
TD_P_A to Pin 8
TD_M_A to Pin 7
TD_P_B to Pin 5
TD_M_B to Pin 4
TD_P_C to Pin 6
TD_M_C to Pin 3
TD_P_D to Pin 2
TD_M_D to Pin 1
Users guide:
https://www.ti.com/lit/ug/snlu209/snlu209.pdf
