Part Number: TUSB8041
Hello, we are developing a USB HUB using TUSB8041.
When I first made the development board, I confirmed that it works normally with USB A to B and B to C cables.
Later, I changed the upstream to Type C and made a new board, but the C to C cable works normally, but the A to C cable caused current consumption and heat generation, causing intermittent disconnection.
(C to C cables generate a current consumption of about 30mA,
When using C to A, power consumption of 150mA or more and heat generation occurred in LDO and MCU)
May I ask you to advise if there is a problem with my circuit or should I use a different method in A to C?
Thank you.
