Part Number: DS160PR410
Hi Expert,
Can you give an example to explain what SHARE REGISTERS is and what CHANNEL REGISTERS is?
From the description below, I can't see the difference between the two.
Xiaoxiang
Hi Expert,
Xiaoxiang
Hi Xiaoxiang,
The SHARE registers for the DS160PR410 are shared across the entire device, while the CHANNEL registers are used to control specific device channels.
The description in the attached image is to indicate that SHARE registers may be used to specify specific channels for programming. A channel's register access is selected using registers 0xFE and 0xFF. After selecting a specific channel for programming, the CHANNEL register map may be used to program channel-specific settings for the device.
David
