TUSB4020BI-Q1: PD USB Charger&Hub configuration issue
Part Number: TUSB4020BI-Q1
Other Parts Discussed in Thread: TPS55289, TPS25772-Q1,
Hi Team,
Project: Automotive PD USB Charger&Hub:
With 2 ports for output, one is a charge only port and another one is a charge + communication port.
The overall scheme currently in use is TPS25772-Q1+TPS55289+TUSB4020BI-Q1 which requires PD power allocation.
Here is the schematic with a description of the PCB Layout and spec:
https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/59/Uniwon-PD60W-2UCU_2600_2Hub-SPEC-updata_5F00_20231128.xls
Requirements: Configure the product function outputs (charging and communication) and disable the communication function of the J2 port to maintain the charging function only.
Could you help check how to configure it? Thanks.
Cherry
