Other Parts Discussed in Thread: DS25BR150, DS38EP100, DS25BR101, DS25CP104A
Dear Team,
do you have a redriver, retimer, buffer or a similar IC for Sony Low voltage LVDS ( subLVDS)?
Vcm=0.9V
Vod = 150mV
d.
You can use a regular LVDS driver coupled with a resistor step down network as detailed here:
https://www.ti.com/lit/an/snla353/snla353.pdf
We don't have any sub-LVDS devices/transceivers.
Malcolm
Hi d,
I'm adding HSD on this thread because I think their devices might be better equipped to handle your solution than anything we have under logic.
Malcolm
Malcolm
What is the data rate requirement? Please see this link for a list of LVDS buffer or repeater that we have, https://www.ti.com/interface/lvds-m-lvds-pecl/products.html#404=Buffer%3BRepeater&.
david
Hi David,
Data rate is 600Mbps . i was looking for small solution size. either 5ch in one package or single channel package.
I found those to are the smallest solution if i'm not wrong.
Can you tell the difference between DS25BR150 and DS38EP100 ?
d.
Hi Malcolm,DS38EP100 is a passive equalizer while DS25BR150 is an active buffer,
Typically we have 4 channels in one package - 5 channels in one package is not what i am aware of.
Please consider DS25CP104A and DS25BR101. These are four and one channel parts. Additionally there is some level of equalization if needed. Please below note link to these two parts data sheet:
https://www.ti.com/lit/ds/symlink/ds25br101.pdf?ts=1701895657262
https://www.ti.com/lit/ds/symlink/ds25cp104a.pdf?ts=1701895264393
Regards, Nasser
