Part Number: DS320PR810
Other Parts Discussed in Thread: DS160PR410
Hi team,
The customer request S-parameter (touchstone format) for DS320PR810.
Could you provide this?
Goto
Hi team,
Goto
Hi Nasser,
Thank you for your support.
I got DS160PR410 S-parameters. I know there is no DS320PR810 model, is that correct?
And can I use this as a DS320PR810 model?
Please let me know if there are any differences that I should be careful of.
Greetings Shuhei,
There is s-parameter model for DS320PR810 as well. Please use the same link i sent earlier to request DS320PR810 model.
Regards, Nasser
Hi Shuhei,
It seems like Nasser's link pointed you to the DS160PR410 design folder based on the URL, apologies for the confusion. The correct folder on My Secure Resources is "PCIE5-REDRIVERS-DESIGN" folder, I tried to grant you access but it seems like you have it. Can you find this folder at this link, or otherwise is it listed in your myTI dashboard?
I am assuming that you are looking for the S-parameter models of the device package. Scroll down to the "DS320PR8xx" section and download the "DS320PR810_822_Model_Release_May2022.zip" file. Inside are the IBIS-AMI and package models for the DS320PR810.
There is a separate zip file in MySecure called "DS320PR810_S4P_Models.zip" that contains S-parameter representations of the entire device at different EQ settings for customers that do not want to use or cannot use the IBIS-AMI model, it can be disregarded if this is not what the customer is doing.
Evan Su
