DP83TD510E: Recommended surge protection devices
Part Number: DP83TD510E
Hi Team,
I know that the DP83TD510E has been tested for surge ratings IEC61000-4-5 Surge ±2KV.
My customer is considering installing lightning surge protection outside the equipment to make it more robust.
Is there a recommended manufacturer of Surge Protective Device?
Kenji
  • Hi Kenji,
    I'm not familiar with external lightning surge protection, can you clarify what this looks like? A block diagram would be useful for me to understand.
    Relative to surge protection, I have only seen ESD diodes used on the MDI lines.
    Thank you,
    Evan
  • Hi Evan,
    Thank you.
    Yes, I have also introduced ESD and TVS diodes on the board.
    I know of cases where surge absorber products are included as a countermeasure, perhaps as a device to be put between the board and the cable.
    I would like you to share some proven surge absorber products that are actually used in SPE.
    Do you share such information within your team?
    Kenji
  • Hi Kenji,
    We don't have any data for an external surge absorber used on the MDI, please contact the TVS/ESD team as they may be in a better position to help you with this.
    Thank you,
    Evan
