Part Number: ESD1LIN24-Q1
Other Parts Discussed in Thread: ESD761-Q1, ESD761
Hi Sir,
May I know if the ESD1LIN24-Q1 can replace the Littelfuse SPHV15-01ETG-C or not?
If it can't, could you please advise the correct solution? Thanks!
Hi Sir,
Hi Henry,
Yes ESD1LIN24-Q1 can replace this device. The clamping voltage is slightly higher but this shouldn't be a concern if the LIN transceiver being protected has a high enough bus fault voltage rating.
Sebastian
Hi Sir,
For the same competitor device for CAN transceiver protection, may I suggest the customer use the ESD761-Q1?
Hi Henry,
Yes ESD761-Q1 can be used to protect the same CAN transceiver. The ESD761-Q1 and ES1LIN24-Q1 are very similar in spec, the ESD761 just has slightly lower capacitance and IEC ESD/Surge ratings.
Sebastian
