Part Number: TCAN1042-Q1
Other Parts Discussed in Thread: TCAN1044A-Q1,
Hi team,
My customer uses TCAN1042DRQ1 in their project. And they met below question, could you please help give some comments? Thank you!
For the TX dominant timeout feature of the TCAN1042DRQ1, as described in the datasheet, the Transmitter feature is turned off when the TCAN1042 triggers the DTO, until TX Pin clears Dominant.
Below is the customer measured waveform, CH1&CH2 are CAN Bus, CH4 is TX Pin;
After TX Pin short to GND, The TCAN1042 triggers the Dominant timeout and releases the CAN Bus in time, but when the dominant error does not clear, CAN bus is also affected by TX dominant error.
This phenomenon is not in line with the datasheet, please help figure out the possible cause, thank you.
Ivy
