Part Number: TPD1E10B06
TPD1E10B06DPYの故障しているかどうか調べる方法を知りたい。
また、故障モードの種類も知りたい。
Hi Minoru,
I had to translate to english so forgive me for any misunderstanding here. Are you asking how to verify if a device is damaged?
These devices can fail short or open, in my experience I have seen more short failures from the input pin to gnd.
Sebastian
Hi Minoru,
I'm not sure I understand correctly, if you're asking why a device fails it is because there was a too much current running through the device. The die will heat up and cause the short failure you're seeing.
Sebastian
