Part Number: DP83867E
Other Parts Discussed in Thread: DP83640
Hello!
We used two PHY chips, DP83640 and DP83867E. We have found the driver for DP83640. Do you provide the relevant driver or development manual for DP83867E?
Thanks!
Hi Hu,
Are you looking for linux driver? If so, linux driver for DP83867 could be found in the following link:
https://www.ti.com/tool/ETHERNET-SW
Hillman Lin
Hi Hillman Lin,
We use the freertos, lwip and the DP83867.
We can develop network port without freertos, or under freertos. So I think it's a universal driver, not a Linux driver which like the DP83640 driver as the website and picture below:
https://www.ti.com.cn/tool/cn/DP83640SW-LIB?keyMatch=&tisearch=search-everything&usecase=partmatches
Thanks!
Hi Hu,
We only have linux and Rtos driver sample. Is customer good for Rtos driver sample?
Hillman Lin
Hi Jiangbo,
Here is the reference Rtos driver. Hope this is useful to you.
* Copyright (c) Texas Instruments Incorporated 2020
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \file dp83867.c
* \brief This file contains the implementation of the DP3867 PHY.
/* Include Files */
#include <stdint.h>
#include <include/core/enet_utils.h>
#include <priv/core/enet_trace_priv.h>
#include <include/phy/enetphy.h>
#include <include/phy/dp83867.h>
#include "enetphy_priv.h"
#include "generic_phy.h"
#include "dp83867_priv.h"
/* Macros & Typedefs */
#define DP83867_OUI (0x080028U)
#define DP83867_MODEL (0x23U)
#define DP83867_REV (0x01U)
/* Structure Declarations */
/* None */
/* Function Declarations */
static bool Dp83867_isPhyDevSupported(EnetPhy_Handle hPhy,
const EnetPhy_Version *version);
static bool Dp83867_isMacModeSupported(EnetPhy_Handle hPhy,
EnetPhy_Mii mii);
static int32_t Dp83867_config(EnetPhy_Handle hPhy,
const EnetPhy_Cfg *cfg,
EnetPhy_Mii mii);
static void Dp83867_setMiiMode(EnetPhy_Handle hPhy,
EnetPhy_Mii mii);
static void Dp83867_setVtmIdleThresh(EnetPhy_Handle hPhy,
uint32_t idleThresh);
static void Dp83867_setDspFFE(EnetPhy_Handle hPhy);
static void Dp83867_fixFldStrap(EnetPhy_Handle hPhy);
static void Dp83867_setLoopbackCfg(EnetPhy_Handle hPhy,
bool enable);
static void Dp83867_enableAutoMdix(EnetPhy_Handle hPhy,
bool enable);
static void Dp83867_setClkShift(EnetPhy_Handle hPhy,
bool txShiftEn,
bool rxShiftEn);
static int32_t Dp83867_setTxFifoDepth(EnetPhy_Handle hPhy,
uint8_t depth);
static int32_t Dp83867_setClkDelay(EnetPhy_Handle hPhy,
uint32_t txDelay,
uint32_t rxDelay);
static int32_t Dp83867_setOutputImpedance(EnetPhy_Handle hPhy,
uint32_t impedance);
static void Dp83867_setGpioMux(EnetPhy_Handle hPhy,
Dp83867_Gpio0Mode gpio0Mode,
Dp83867_Gpio1Mode gpio1Mode);
static void Dp83867_setLedMode(EnetPhy_Handle hPhy,
const Dp83867_LedMode *ledMode);
static void Dp83867_restart(EnetPhy_Handle hPhy);
static void Dp83867_reset(EnetPhy_Handle hPhy);
static bool Dp83867_isResetComplete(EnetPhy_Handle hPhy);
static void Dp83867_rmwExtReg(EnetPhy_Handle hPhy,
uint32_t reg,
uint16_t mask,
uint16_t val);
static void Dp83867_printRegs(EnetPhy_Handle hPhy);
/* Global Variables */
EnetPhy_Drv gEnetPhyDrvDp83867 =
.name = "dp83867",
.isPhyDevSupported = Dp83867_isPhyDevSupported,
.isMacModeSupported = Dp83867_isMacModeSupported,
.config = Dp83867_config,
.reset = Dp83867_reset,
.isResetComplete = Dp83867_isResetComplete,
.readExtReg = GenericPhy_readExtReg,
.writeExtReg = GenericPhy_writeExtReg,
.printRegs = Dp83867_printRegs,
/* Function Definitions */
void Dp83867_initCfg(Dp83867_Cfg *cfg)
cfg->txClkShiftEn = false;
cfg->rxClkShiftEn = false;
cfg->txDelayInPs = 2000U; /* 2.00 ns */
cfg->rxDelayInPs = 2000U; /* 2.00 ns */
cfg->txFifoDepth = 4U; /* 4 bytes/nibbles */
cfg->impedanceInMilliOhms = 50000U; /* 50 ohms */
cfg->idleCntThresh = 5U;
cfg->gpio0Mode = DP83867_GPIO0_RXERR;
cfg->gpio1Mode = DP83867_GPIO1_COL;
cfg->ledMode[0] = DP83867_LED_LINKED;
cfg->ledMode[1] = DP83867_LED_LINKED_1000BT;
cfg->ledMode[2] = DP83867_LED_RXTXACT;
cfg->ledMode[3] = DP83867_LED_LINKED_100BTX;
bool supported = false;
if ((version->oui == DP83867_OUI) &&
(version->model == DP83867_MODEL) &&
(version->revision == DP83867_REV))
supported = true;
else
supported = false;
return supported;
EnetPhy_Mii mii)
bool supported;
switch (mii)
case ENETPHY_MAC_MII_MII:
case ENETPHY_MAC_MII_GMII:
case ENETPHY_MAC_MII_RGMII:
supported = true;
break;
default:
supported = false;
break;
return supported;
EnetPhy_Mii mii)
const Dp83867_Cfg *extendedCfg = (const Dp83867_Cfg *)cfg->extendedCfg;
uint32_t extendedCfgSize = cfg->extendedCfgSize;
bool enableAutoMdix = true;
int32_t status = ENETPHY_SOK;
if ((extendedCfg == NULL) ||
(extendedCfgSize != sizeof(*extendedCfg)))
ENETTRACE_ERR("PHY %u: invalid config params (cfg=%p, size=%u)\n",
hPhy->addr, extendedCfg, extendedCfgSize);
status = ENETPHY_EINVALIDPARAMS;
/* Set Viterbi detector idle count threshold and DSP FFE Equalizer */
if (status == ENETPHY_SOK)
Dp83867_setVtmIdleThresh(hPhy, extendedCfg->idleCntThresh);
Dp83867_setDspFFE(hPhy);
/* Apply workaround for FLD threshold when using bootstrap */
Dp83867_fixFldStrap(hPhy);
/* Set loopback configuration: enable or disable */
/* To maintain the desired operating mode, Auto-Negotiation should be
* disabled before enabling the near-end loopback mode (MII loopback is
* the only mode supported by the driver). That's taken care by the
* PHY framework when setting PHY's manual mode parameters */
Dp83867_setLoopbackCfg(hPhy, cfg->loopbackEn);
/* Auto-MDIX should be disabled before selecting the Near-End Loopback
* mode. MDI or MDIX configuration should be manually configured */
enableAutoMdix = !cfg->loopbackEn;
/* Software restart is required after Viterbi idle detector and loopback
* configuration change */
Dp83867_restart(hPhy);
/* Enable Auto-MDIX and Robust Auto-MDIX */
Dp83867_enableAutoMdix(hPhy, enableAutoMdix);
/* Set MII mode: MII or RGMII */
Dp83867_setMiiMode(hPhy, mii);
/* Config RGMII TX and RX clock shift and clock delay */
if ((status == ENETPHY_SOK) &&
(mii == ENETPHY_MAC_MII_RGMII))
Dp83867_setClkShift(hPhy,
extendedCfg->txClkShiftEn,
extendedCfg->rxClkShiftEn);
status = Dp83867_setClkDelay(hPhy,
extendedCfg->txDelayInPs,
extendedCfg->rxDelayInPs);
/* Config TX FIFO depth */
status = Dp83867_setTxFifoDepth(hPhy, extendedCfg->txFifoDepth);
/* Set output impedance */
status = Dp83867_setOutputImpedance(hPhy, extendedCfg->impedanceInMilliOhms);
/* Set GPIO mux control (RGZ devices only) */
Dp83867_setGpioMux(hPhy,
extendedCfg->gpio0Mode,
extendedCfg->gpio1Mode);
/* Set LED configuration */
Dp83867_setLedMode(hPhy, extendedCfg->ledMode);
return status;
EnetPhy_Mii mii)
uint16_t val = 0U;
ENETTRACE_DBG("PHY %u: MII mode: %u\n", hPhy->addr, mii);
if (mii == ENETPHY_MAC_MII_RGMII)
val = RGMIICTL_RGMIIEN;
Dp83867_rmwExtReg(hPhy, DP83867_RGMIICTL, val, RGMIICTL_RGMIIEN);
ENETTRACE_DBG("PHY %u: Viterbi detector idle count thresh: %u\n", hPhy->addr, idleThresh);
Dp83867_rmwExtReg(hPhy, DP83867_VTMCFG, VTMCFG_IDLETHR_MASK, idleThresh);
ENETTRACE_DBG("PHY %u: DSP FFE Equalizer: %u\n", hPhy->addr, DSPFFECFG_FFEEQ_SHORTCABLE);
/* As per datasheet, it improves Short Cable performance and will not effect
* Long Cable performance */
Dp83867_rmwExtReg(hPhy, DP83867_DSPFFECFG,
DSPFFECFG_FFEEQ_MASK,
uint16_t val;
/* As per datasheet, when using strap to enable FLD feature, this bit defaults to 0x2.
* Register write is needed to change it to 0x1 */
EnetPhy_readExtReg(hPhy, DP83867_STRAPSTS2, &val);
if ((val & STRAPSTS2_FLD_MASK) != 0U)
ENETTRACE_DBG("PHY %u: Apply FLD threshold workaround\n", hPhy->addr);
Dp83867_rmwExtReg(hPhy, DP83867_FLDTHRCFG, FLDTHRCFG_FLDTHR_MASK, 1U);
bool enable)
uint16_t val;
ENETTRACE_DBG("PHY %u: %s loopback\n", hPhy->addr, enable ? "enable" : "disable");
if (enable)
val = LOOPCR_CFG_LOOPBACK;
else
val = LOOPCR_CFG_NORMAL;
/* Specific predefined loopback configuration values are required for
* normal mode or loopback mode */
GenericPhy_writeExtReg(hPhy, DP83867_LOOPCR, val);
bool enable)
uint16_t val;
if (enable)
val = PHYCR_MDICROSSOVER_AUTO;
else
val = PHYCR_MDICROSSOVER_MDI;
ENETTRACE_DBG("PHY %u: %s automatic cross-over\n",
EnetPhy_rmwReg(hPhy, DP83867_PHYCR,
PHYCR_MDICROSSOVER_MASK,
val);
if (enable)
ENETTRACE_DBG("PHY %u: enable Robust Auto-MDIX\n", hPhy->addr);
EnetPhy_rmwReg(hPhy, DP83867_CFG3,
CFG3_ROBUSTAUTOMDIX,
CFG3_ROBUSTAUTOMDIX);
bool txShiftEn,
bool rxShiftEn)
uint16_t val;
ENETTRACE_DBG("PHY %u: clock shift TX:%s RX:%s\n",
hPhy->addr,
txShiftEn ? "enable" : "disable",
rxShiftEn ? "enable" : "disable");
val = (txShiftEn == true) ? RGMIICTL_TXCLKDLY : 0U;
val |= (rxShiftEn == true) ? RGMIICTL_RXCLKDLY : 0U;
RGMIICTL_TXCLKDLY | RGMIICTL_RXCLKDLY,
val);
uint8_t depth)
uint16_t val = 0U;
switch (depth)
case 3U:
val = PHYCR_TXFIFODEPTH_3B;
break;
case 4U:
val = PHYCR_TXFIFODEPTH_4B;
break;
case 6U:
val = PHYCR_TXFIFODEPTH_6B;
break;
case 8U:
val = PHYCR_TXFIFODEPTH_8B;
break;
default:
break;
ENETTRACE_DBG("PHY %u: set FIFO depth %u\n", hPhy->addr, depth);
EnetPhy_rmwReg(hPhy, DP83867_PHYCR, PHYCR_TXFIFODEPTH_MASK, val);
else
ENETTRACE_ERR("PHY %u: invalid FIFO depth: %u\n", hPhy->addr, depth);
return status;
uint32_t txDelay,
uint32_t rxDelay)
uint16_t val;
uint32_t delay;
uint32_t delayCtrl;
if ((txDelay <= RGMIIDCTL_DELAY_MAX) &&
(rxDelay <= RGMIIDCTL_DELAY_MAX))
ENETTRACE_DBG("PHY %u: set delay %u ps TX, %u ps RX\n", hPhy->addr, txDelay, rxDelay);
/* Avoids wrong value of delayCtrl if txDelay is 0 */
delay = (txDelay > 0U) ? txDelay : 1U;
delayCtrl = ENETPHY_DIV_ROUNDUP(delay, RGMIIDCTL_DELAY_STEP) - 1U;
val = (uint16_t)((delayCtrl << RGMIIDCTL_TXDLYCTRL_OFFSET) & RGMIIDCTL_TXDLYCTRL_MASK);
/* Avoids wrong value of delayCtrl if rxDelay is 0 */
delay = (rxDelay > 0U) ? rxDelay : 1U;
val |= (uint16_t)((delayCtrl << RGMIIDCTL_RXDLYCTRL_OFFSET) & RGMIIDCTL_RXDLYCTRL_MASK);
GenericPhy_writeExtReg(hPhy, DP83867_RGMIIDCTL, val);
else
ENETTRACE_ERR("PHY %u: invalid delay (TX=%u RX=%u)\n", hPhy->addr, txDelay, rxDelay);
return status;
uint32_t impedance)
uint32_t val;
if ((impedance >= IOMUXCFG_IOIMPEDANCE_MIN) &&
(impedance <= IOMUXCFG_IOIMPEDANCE_MAX))
ENETTRACE_DBG("PHY %u: set output impedance to %u milli-ohms\n", hPhy->addr, impedance);
val = (IOMUXCFG_IOIMPEDANCE_MAX - impedance) * IOMUXCFG_IOIMPEDANCE_MASK;
val = (val + IOMUXCFG_IOIMPEDANCE_RANGE / 2) / IOMUXCFG_IOIMPEDANCE_RANGE;
Dp83867_rmwExtReg(hPhy, DP83867_IOMUXCFG,
IOMUXCFG_IOIMPEDANCE_MASK,
val);
else
ENETTRACE_ERR("PHY %u: out-of-range impedance: %u\n", hPhy->addr, impedance);
return status;
int16_t gpio0;
int16_t gpio1;
ENETTRACE_DBG("PHY %u: set gpio0 = mode%u, gpio1 = mode%u\n", hPhy->addr, gpio0Mode, gpio1Mode);
gpio0 = (uint16_t)gpio0Mode << GPIOMUXCTRL_GPIO0_OFFSET;
gpio0 &= GPIOMUXCTRL_GPIO0_MASK;
gpio1 = (uint16_t)gpio1Mode << GPIOMUXCTRL_GPIO1_OFFSET;
gpio1 &= GPIOMUXCTRL_GPIO1_MASK;
Dp83867_rmwExtReg(hPhy, DP83867_GPIOMUXCTRL,
GPIOMUXCTRL_GPIO1_MASK | GPIOMUXCTRL_GPIO0_MASK,
gpio1 | gpio0);
uint16_t val;
ENETTRACE_DBG("PHY %u: set LED0 = mode%u, LED1 = mode%u, LED2 = mode%u, LED3 = mode%u\n",
hPhy->addr, ledMode[0], ledMode[1], ledMode[2], ledMode[3]);
val = ((uint16_t)ledMode[0] << LEDCR1_LED0SEL_OFFSET) & LEDCR1_LED0SEL_MASK;
val |= ((uint16_t)ledMode[1] << LEDCR1_LED1SEL_OFFSET) & LEDCR1_LED1SEL_MASK;
val |= ((uint16_t)ledMode[2] << LEDCR1_LED2SEL_OFFSET) & LEDCR1_LED2SEL_MASK;
val |= ((uint16_t)ledMode[3] << LEDCR1_LED3SEL_OFFSET) & LEDCR1_LED3SEL_MASK;
EnetPhy_writeReg(hPhy, DP83867_LEDCR1, val);
/* Software restart: full reset, not including registers */
ENETTRACE_DBG("PHY %u: soft-restart\n", hPhy->addr);
EnetPhy_rmwReg(hPhy, DP83867_CTRL, CTRL_SWRESTART, CTRL_SWRESTART);
/* Global software reset: all PHY internal circuits including IEEE-defined
* registers and all extended registers are reset */
ENETTRACE_DBG("PHY %u: global soft-reset\n", hPhy->addr);
EnetPhy_rmwReg(hPhy, DP83867_CTRL, CTRL_SWRESET, CTRL_SWRESET);
int32_t status;
uint16_t val;
bool complete = false;
/* Reset is complete when RESET bit has self-cleared */
status = EnetPhy_readReg(hPhy, DP83867_CTRL, &val);
complete = ((val & CTRL_SWRESET) == 0U);
ENETTRACE_DBG("PHY %u: global soft-reset is %scomplete\n", hPhy->addr, complete ? "" : "not");
return complete;
uint32_t reg,
uint16_t mask,
uint16_t val)
uint16_t devad = MMD_CR_DEVADDR;
uint16_t data;
int32_t status;
ENETTRACE_VERBOSE("PHY %u: write reg %u mask 0x%04x val 0x%04x\n",
hPhy->addr, reg, mask, val);
EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_ADDR);
EnetPhy_writeReg(hPhy, PHY_MMD_DR, reg);
EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_DATA_NOPOSTINC);
status = EnetPhy_readReg(hPhy, PHY_MMD_DR, &data);
data = (data & ~mask) | (val & mask);
EnetPhy_writeReg(hPhy, PHY_MMD_DR, data);
uint32_t phyAddr = hPhy->addr;
uint16_t val;
EnetPhy_readReg(hPhy, PHY_BMCR, &val);
EnetUtils_printf("PHY %u: BMCR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_BMSR, &val);
EnetUtils_printf("PHY %u: BMSR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_PHYIDR1, &val);
EnetUtils_printf("PHY %u: PHYIDR1 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_PHYIDR2, &val);
EnetUtils_printf("PHY %u: PHYIDR2 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_ANAR, &val);
EnetUtils_printf("PHY %u: ANAR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_ANLPAR, &val);
EnetUtils_printf("PHY %u: ANLPAR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_ANER, &val);
EnetUtils_printf("PHY %u: ANER = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_ANNPTR, &val);
EnetUtils_printf("PHY %u: ANNPTR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_ANNPRR, &val);
EnetUtils_printf("PHY %u: ANNPRR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_GIGCR, &val);
EnetUtils_printf("PHY %u: CFG1 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_GIGSR, &val);
EnetUtils_printf("PHY %u: STS1 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, PHY_GIGESR, &val);
EnetUtils_printf("PHY %u: 1KSCR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_PHYCR, &val);
EnetUtils_printf("PHY %u: PHYCR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_PHYSTS, &val);
EnetUtils_printf("PHY %u: PHYSTS = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_MICR, &val);
EnetUtils_printf("PHY %u: MICR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_ISR, &val);
EnetUtils_printf("PHY %u: ISR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_CFG2, &val);
EnetUtils_printf("PHY %u: CFG2 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_RECR, &val);
EnetUtils_printf("PHY %u: RECR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_BISCR, &val);
EnetUtils_printf("PHY %u: BISCR = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_STS2, &val);
EnetUtils_printf("PHY %u: STS2 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_LEDCR1, &val);
EnetUtils_printf("PHY %u: LEDCR1 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_LEDCR2, &val);
EnetUtils_printf("PHY %u: LEDCR2 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_LEDCR3, &val);
EnetUtils_printf("PHY %u: LEDCR3 = 0x%04x\n", phyAddr, val);
EnetPhy_readReg(hPhy, DP83867_CFG3, &val);
EnetUtils_printf("PHY %u: CFG3 = 0x%04x\n", phyAddr, val);
EnetUtils_printf("PHY %u: CTRL = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_RGMIICTL, &val);
EnetUtils_printf("PHY %u: RGMIICTL = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_FLDTHRCFG, &val);
EnetUtils_printf("PHY %u: FLDTHRCFG = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_VTMCFG, &val);
EnetUtils_printf("PHY %u: VTMCFG = 0x%04x\n", phyAddr, val);
EnetUtils_printf("PHY %u: STRAPSTS2 = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_RGMIIDCTL, &val);
EnetUtils_printf("PHY %u: RGMIIDCTL = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_LOOPCR, &val);
EnetUtils_printf("PHY %u: LOOPCR = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_DSPFFECFG, &val);
EnetUtils_printf("PHY %u: DSPFFECFG = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_IOMUXCFG, &val);
EnetUtils_printf("PHY %u: IOMUXCFG = 0x%04x\n", phyAddr, val);
EnetPhy_readExtReg(hPhy, DP83867_GPIOMUXCTRL, &val);
EnetUtils_printf("PHY %u: GPIOMUXCTRL = 0x%04x\n", phyAddr, val);
Hillman Lin
