Part Number: DP83867IR
HI teams,
We are considering a GigE-vision interface module using Texas Instruments' PHY device "DP83867IR". I'm also considering an RJ-45 connector to use in that case. Could you please let me know if there is an RJ-45 connector recommended for the PHY device "DP83867IR"? The physical layer is assumed to be "100/1000BASE-T".
At the time of consideration, we were using Xilinx's evaluation board "SP701", and on that evaluation board we used Würth Elektronik's "7499111221A", but since that connector is large. I would like to see if there are any other recommended connectors.
Thank you for your help.
Taito Takemura
