Part Number: DP83826E
Other Parts Discussed in Thread: AM3356
I have questions about power-on and reset release timing of DP83826 and AM3356.
How should I consider the power-on timing and reset signal release timing for DP83826 and AM3356(MPU)?
Q1.
Does DP83826 need to be power-on after MPU have been power-on and stable?
Or no power-on timing need to be consider between PHY and MPU?
Q2.
In general, is the DP83826 supplied from the same power supply as the MCU at the same time,
and is the reset release of the DP83826 done from the MCU?
If so, at what timing should the reset of the DP83826 be released from the MCU?
best regards,
g.f.
