Part Number: DS90C385A
Other Parts Discussed in Thread: SN75LVDS83B, SN65LVDS93B-Q1, DS90C3201
Is there p2p compatible one with THC63LVDM83D (Thine)?
Thanks.
Brian
Thanks.
Brian
Hello Brian,
we do have the following devices which are somehow similar to the above mentioned. You may need to go through their datasheets to make sure if they are pin compatible or not.
SN75LVDS83B - SER - 28 Parallel TTL inputs to 4 LVDS+CLK output - 10-135MHz
SN65LVDS93B-Q1 - SER - 28 Parallel TTL inputs to 4 LVDS+CLK outputs - 10-85MHz
DS90C3201 - SER - 70 Parallel TTL inputs to 10 LVDS+CLK outputs - 8-135MHz
