I am using TS5USBA224RSWR switch in my design as shown in below picture. The design has both differential and single ended audio signals passing through switch.
The input to input at the switch D+/R,D–/L pins comes from the audio codec output (3.4Vpp max) & this will be switched to either op amp1 or 2 based on SEL line.
Please confirm if this approach is fine. Any other points to be taken care of?
Thanks & Rgards,
Ranjini.R
