Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869
I use the DP83869HM reference on 2 identical boards.
The DP83869HM is used between a 1000BASE-T ethernet interface and a SFP interface (copper or fiber).
On the first board, a copper SFP module and a fiber SFP module are functional.
On the second board, only the fiber SFP module is functional and not with a copper SFP module.
I see that the marking is different on the DP83869HM components.
On the first board, the marking is below
On the second board, the marking is below
Do you know why the copper SFP module is functional on the first board and not on the second board ?
Thanks in advance for your answer.
Best regards
Arnaud LE TUTOUR
