Part Number: TCAN1043A-Q1
I'm looking to potentially use the TCAN1043A-Q1 INH pin to enable/disable power supply IC's with CAN wake and CAN sleep commands without any intervention from the Host microcontroller.
My understanding is that once I send CAN wake command, the INH pin will go to VBATT, and once the CAN sleep command is sent the INH pin will get a HI-Z state and a pull down resistor will pull it low. We plan to tie this node to the enable of the front end regulator and use it to enable/disable the power supply. Does TI have any application notes or application recommendations that can show use cases like this?.
