Part Number: TLK10002
Hi team,
could you help with below questions?
- Does the PRBS Generator in this device rely on external signal input? If the data or clock signal is input at the RX end, the PRBS code stream can be sent at the TX end.
If the PRBS Generator does not rely on external signal input, how to adjust the PRBS stream rate? - If the device need to enable the PRBS function, do you only need to configure registers B.7:6 and B.13:12 through MDIO and pull the PRBSEN pin high?
