Part Number: SN65LBC184
Hi team,
Will there have any risk for customer to use SN65LBC184 for 115200 bps?
Brian
Hi team,
Brian
Hi Brian,
As Clemen's has pointed out, the LBC184 device is spec'd to handle higher data rates so it can send a slower datarate like 115200. With higher datarate devices, the differential output usually has faster slewrates than a slower data rate device. On a lightly loaded bus, this can result in some additional overshoots/undershoots but with low data rates this generally isn't an issue and if you do see it and want to minimize it you could add a capacitor in parallel with the differential signals to help attenuate/dampen the swings.
-Bobby
