Part Number: DP83TG720S-Q1
Other Parts Discussed in Thread: DP83TC814S-Q1
Hi Team,
Hope you are doing well!
1. Can you provide the configuration file of DP83TG720S-Q1 Ethernet PHY?
2. Can DP83TG720S/R/-TC share a PHY configuration file?
Thanks!
Hi Team,
Thanks!
Hi Guohai,
1. Do you mean the register writes required for the DP83TG720 at start up for Open Alliance compliance or the linux .c file?
The register writes required at start up can be found in this app note: https://www.ti.com/lit/an/snla371a/snla371a.pdf
The linux file is attached here:
2. Yes, the DP83TG720R/S can share the same configuration. However, the DP83TCxxx parts have different configurations from the DP83TG720 parts.
Melissa
Hi Melissa,
Do you also have the linux file of DP83TC814S-Q1 can provide ? Thanks!
And how/where can I get that by myself?
Hi Guohai,
I've attached the driver for the 812. This will work for the 812 aswell.
I will post an FAQ soon of where you can find the linux drivers and link it here.
Melissa
