Part Number: TDP1204
Does the TDP1204 support DP (single mode) to HDMI output?
If not what alternative devices do you recommend?
Thanks in advance.
Thanks in advance.
Hello, Richard,
No. The TDP1204 does not support DP to HDMI protocol conversion. However, you can still use TDP1204 after a protocol converter to redrive the signal coming out of the signal converter.
Unfortunately, our portfolio does not have any protocol converters. Therefore, you could look at this active protocol converter to see if it fits your needs: https://www.paradetech.com/products/ps196/.
Zach
Thanks for your response.
Unfortunately the ParadeTech parts are only 0-70C temperature range.
Hi, Richard,
You are welcome. Is there anything I can do to assist you further?
Zach
Richard,
If there is nothing else further, I am going to close this ticket.
Zach
