Part Number: DS110DF410
Other Parts Discussed in Thread: DS100DF410, TLK1002A
Hello Team,
Do we have the substituted chip for DS110DF410, we only need the Data Rates 1Gbps for Gigabit fiber optic interface.
Thank you!
Hello Team,
Thank you!
Can you clarify, does your application use 1 GbE (line rate of 1.25 Gbps)? Or does it use a line rate of 1 Gbps? Are you looking specifically for a retimer, or would a redriver be sufficient?
I can help find a substitute part based on your answers to these questions.
Lucas
Hello Lucas,
We apply it in 1 GbE (line rate of 1.25 Gbps) system, it is better to use pin to pin substitute base on DS110DF410, or same function but low cost chip.
Thanks!
Best
DS100DF410 is pin-to-pin compatible with DS110DF410 and supports 10 GbE and 1 GbE rates only.
TLK1002A is a retimer supporting 1-1.3 Gbps but is not pin-to-pin compatible with DS110DF410.
As far as I'm aware, we do not have any other ethernet retimers designed for 1 GbE. If you are interested in redrivers/repeaters, I can make additional part recommendations but they will not be pin-to-pin compatible with DS110DF410.
Lucas
