Part Number: LMH1228
Other Parts Discussed in Thread: LMH1297EVM
Hi everyone
I'm trying to lock each of the outputs, SDI_Out1 and SDI_Out2, with different slew rates following tables 3.14.5.2.1 and 3.14.5.2.2 in the programming manual.
I did a test trying to leave SDI_Out1 with slew rate in SD(270M) and SDI_Out2 with slew rate in HD(3G/1.5G).
At the entrance it was tested with 1080 and 2160, but in none of the cases did the commands work to lock in the desired slew rate settings.
I would like to know what can be done besides following what is described in the aforementioned tables.
Thanks, Marcelo
