Part Number: LMH0397
SPI bus addressing: If several devices are in a SPI daisy chain, how do you access each device individually? For example, if you want each device in the chain to be configured individually, or if you want to access only one device but not the others? I do not see any means to set the address via pins as is the case with SMB.
