Part Number: DS110DF111
Can you please provide some details regarding what SBT does?
My customer found that they need to disable SBT in order to achieve a link in a 10GBase-SR application using SFP+ transceivers.
Brian
Brian
Hi Brian,
SBT checks the number of bit transitions within a window of time. If the number of transitions do not meet the required threshold, then SBT prevents CDR lock. I would guess your customer's pattern has a low number of bit transitions, which would explain why disabling SBT is necessary to obtain CDR lock.
Lucas
Hi Lucas,
Thank you. Follow-up questions:
How many transitions is the DS110DF111 looking for and how long is the window of time?
Would you expect SBT not to work in the case of 10GBase-SR during the linkup stage?
Brian
Hi Brian,
Unfortunately I don't have a clear answer to give here as this is confidential design information.
I would normally expect the single bit limit to be reached with ordinary 64b/66b encoded 10GbE data. If the data/pattern being transmitted has an especially low number of bit transitions, then this would explain why the single bit limit isn't being reached. Disabling SBT is a common debug/workaround step for CDR lock issues, so I don't have any concern if it is necessary for the customer to obtain CDR lock.
Lucas
