Part Number: DP83TC812S-Q1
can you please provide me information about current consumption for DP93TC812S if I am using SGMII interface with the following voltage rails:
VDDIO and VDDA are connected to the 3V3 and VDDMAC is connected to 1V8. All voltages will be provided from external LDOs.
VSLEEP is connected to 3V3_permanent voltage and by datasheet current consumption on this pin should be between 7 and 18 microAmpers. If I am wrong please correct me
I hope that you can find time to answer me, because I could not find those informations based on your datasheet. (There is no case with different voltages for VDDIO and VDDMAC)
Thank you in advance!
Kind regards,
Anes
