Part Number: DP83822H
Other Parts Discussed in Thread: AM5728, , DP83822IF
Hi TI,
We use custom designed AM5728 board with MitySOM AM5728 SOM. We have PRU ICSS ethernet with DP83822.
Upon booting i got the following error.
Could not get PHY for ethernet@48484000: addr 0
Schematic diagram and bootlog is attached herewith. please check the issue and help us.
Thanks and regards
Sandeep S
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.03.04 15:25:43 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2019.01-g3a254cb755-dirty (Nov 22 2023 - 10:00:40 +0530)
DRA752-GP ES2.0
no pinctrl state for default mode
** Unable to read file dra7-ipu1-fw.xem4 **
Firmware loading failed
Trying to boot from MMC1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
Loading Environment from MMC... Card did not respond to voltage select!
*** Warning - No block device, using default environment
U-Boot 2019.01-g3a254cb755-dirty (Nov 22 2023 - 10:00:40 +0530)
CPU : DRA752-GP ES2.0
Model: TI AM5748 IDK
Board: MitySOM-57x Dev Kit Non-FPGA
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
MitySOM-57x - Model No: 5728-PX-4AA-RI Serial No: 21005273 Part Number: 80-001446RI-3A
Warning: fastboot.board_rev: unknown board revision
invalid mmc device
i2c_write: error waiting for data ACK (status=0x116)
cdce9xx_reg_write: failed for addr:5, ret:-121
board_set_pru_ethaddr
Net: Could not get PHY for ethernet@48484000: addr 0
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
** Unable to read file uEnv.txt **
4469248 bytes read in 196 ms (21.7 MiB/s)
90412 bytes read in 5 ms (17.2 MiB/s)
Loading Device Tree to 8ffe6000, end 8ffff12b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.94-g7317dfbd4116-dirty (mitysom@mitysom-OptiPlex-5040) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Mon Nov 20 14:26:50 IST 2023
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Critical Link MitySOM-AM57x
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 128 MiB at 0x00000000f6c00000
[ 0.000000] OMAP4: Map 0x00000000fed00000 to (ptrval) for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 460096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 cma=128MB drm.edid_firmware=edid/1920x1080.bin video=HDMI-A-1:1920x1080 root=PARTUUID=041ee9b5-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1550312K/1847296K available (10240K kernel code, 337K rwdata, 2824K rodata, 2048K init, 272K bss, 34840K reserved, 262144K cma-reserved, 1160192K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 338 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 273 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000018] Switching to timer-based delay loop, resolution 162ns
[ 0.000292] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000301] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000744] Console: colour dummy device 80x30
[ 0.000788] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000802] pid_max: default: 32768 minimum: 301
[ 0.000923] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000938] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001494] CPU: Testing write buffer coherency: ok
[ 0.001530] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001743] /cpus/cpu@0 missing clock-frequency property
[ 0.001763] /cpus/cpu@1 missing clock-frequency property
[ 0.001775] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059920] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079934] rcu: Hierarchical SRCU implementation.
[ 0.100128] EFI services will not be available.
[ 0.119999] smp: Bringing up secondary CPUs ...
[ 0.200386] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.200392] CPU1: Spectre v2: using ICIALLU workaround
[ 0.200514] smp: Brought up 1 node, 2 CPUs
[ 0.200527] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.200536] CPU: All CPU(s) started in HYP mode.
[ 0.200543] CPU: Virtualization extensions available.
[ 0.201104] devtmpfs: initialized
[ 0.217781] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.218037] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.218055] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.222342] pinctrl core: initialized pinctrl subsystem
[ 0.222852] DMI not present or invalid.
[ 0.223129] NET: Registered protocol family 16
[ 0.224323] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.225224] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.418126] cpuidle: using governor ladder
[ 0.418161] cpuidle: using governor menu
[ 0.428212] OMAP GPIO hardware version 0.1
[ 0.454139] No ATAGs?
[ 0.454213] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.454227] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.455060] OMAP DMA hardware revision 0.0
[ 0.466751] edma 43300000.edma: memcpy is disabled
[ 0.470142] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.477331] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.563125] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.563310] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.563549] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.563784] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.564156] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.564331] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.564613] iommu: Adding device 58820000.ipu to group 1
[ 0.564694] iommu: Adding device 55020000.ipu to group 2
[ 0.564828] iommu: Adding device 40800000.dsp to group 0
[ 0.565073] iommu: Adding device 41000000.dsp to group 3
[ 0.566306] SCSI subsystem initialized
[ 0.567350] palmas 0-0058: Irq flag is 0x00000008
[ 0.593552] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.595176] SMPS12: supplied by regulator-dummy
[ 0.596792] SMPS3: supplied by VMAIN
[ 0.598280] SMPS45: supplied by regulator-dummy
[ 0.600018] SMPS6: supplied by VMAIN
[ 0.601613] SMPS7: supplied by VMAIN
[ 0.603376] SMPS8: supplied by VMAIN
[ 0.604577] random: fast init done
[ 0.604967] SMPS9: supplied by VMAIN
[ 0.605878] LDO1: supplied by VMAIN
[ 0.621223] LDO2: supplied by VMAIN
[ 0.641243] LDO3: supplied by VMAIN
[ 0.661263] LDO4: supplied by VMAIN
[ 0.661923] LDO5: supplied by regulator-dummy
[ 0.662587] LDO6: supplied by regulator-dummy
[ 0.663249] LDO7: supplied by regulator-dummy
[ 0.663912] LDO8: supplied by regulator-dummy
[ 0.664573] LDO9: supplied by VMAIN
[ 0.671570] LDOLN: supplied by VMAIN
[ 0.681304] LDOUSB: supplied by VMAIN
[ 0.693769] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.694697] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.694905] media: Linux media interface: v0.10
[ 0.694946] videodev: Linux video capture interface: v2.00
[ 0.695023] pps_core: LinuxPPS API ver. 1 registered
[ 0.695032] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.695053] PTP clock support registered
[ 0.695083] EDAC MC: Ver: 3.0.0
[ 0.695855] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.696112] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.700909] Advanced Linux Sound Architecture Driver Initialized.
[ 0.701726] clocksource: Switched to clocksource arch_sys_counter
[ 0.710042] NET: Registered protocol family 2
[ 0.710622] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.710652] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.710714] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.710984] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.711060] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.711095] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.711225] NET: Registered protocol family 1
[ 0.731661] RPC: Registered named UNIX socket transport module.
[ 0.731671] RPC: Registered udp transport module.
[ 0.731680] RPC: Registered tcp transport module.
[ 0.731688] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.732775] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.732970] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.733953] Initialise system trusted keyrings
[ 0.734087] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.738994] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.749485] NFS: Registering the id_resolver key type
[ 0.749510] Key type id_resolver registered
[ 0.749520] Key type id_legacy registered
[ 0.749563] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.751209] Key type asymmetric registered
[ 0.751221] Asymmetric key parser 'x509' registered
[ 0.751269] bounce: pool size: 64 pages
[ 0.751302] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.751312] io scheduler noop registered
[ 0.751322] io scheduler deadline registered
[ 0.751418] io scheduler cfq registered (default)
[ 0.751429] io scheduler mq-deadline registered
[ 0.751438] io scheduler kyber registered
[ 0.757232] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.764586] V3_3D: supplied by smps9
[ 0.764823] aic_dvdd: supplied by V3_3D
[ 0.764886] vtt_fixed: supplied by V3_3D
[ 0.811535] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.815101] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
[ 0.816043] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 44, base_baud = 3000000) is a 8250
[ 1.796446] console [ttyS2] enabled
[ 1.800875] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 45, base_baud = 3000000) is a 8250
[ 1.811822] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 1.812324] random: crng init done
[ 1.821616] omapdss_dss 58000000.dss: Linked as a consumer to regulator.22
[ 1.828664] DSS: OMAP DSS rev 6.1
[ 1.834975] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.15
[ 1.842511] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.15
[ 1.862832] brd: module loaded
[ 1.872174] loop: module loaded
[ 1.881372] m25p80 spi0.0: found n25q256ax1, expected s25fl256s1
[ 1.887768] m25p80 spi0.0: n25q256ax1 (32768 Kbytes)
[ 1.892857] 7 fixed-partitions partitions found on MTD device spi0.0
[ 1.899238] Creating 7 MTD partitions on "spi0.0":
[ 1.904078] 0x000000000000-0x000000040000 : "QSPI.SPL"
[ 1.909954] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 1.916108] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 1.922860] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 1.929317] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 1.936508] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 1.942632] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 1.949782] libphy: Fixed MDIO Bus: probed
[ 2.011768] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.019464] libphy: 48485000.mdio: probed
[ 2.027847] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 2.035910] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 2.044498] cpsw 48484000.ethernet: Detected MACID = f8:33:31:74:fa:06
[ 2.051114] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.057518] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.062830] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.070826] cpsw 48484000.ethernet: cpsw: Detected MACID = f8:33:31:74:fa:07
[ 2.079149] i2c /dev entries driver
[ 2.085867] gpio-fan gpio_fan: GPIO fan initialized
[ 2.115386] cpu cpu0: Linked as a consumer to regulator.6
[ 2.120889] cpu cpu0: Linked as a consumer to regulator.29
[ 2.128429] sdhci: Secure Digital Host Controller Interface driver
[ 2.134712] sdhci: Copyright(c) Pierre Ossman
[ 2.140251] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.146603] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 2.155457] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 2.160252] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.28
[ 2.167288] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13
[ 2.174444] sdhci-omap 4809c000.mmc: Dropping the link to regulator.13
[ 2.181048] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.2
[ 2.187991] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13
[ 2.195202] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 2.227702] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 2.235257] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.5
[ 2.242074] sdhci-omap 480b4000.mmc: Dropping the link to regulator.5
[ 2.248626] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
[ 2.255521] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.5
[ 2.262379] sdhci-omap 480b4000.mmc: Cannot get pinctrl
[ 2.267854] sdhci-omap 480b4000.mmc: Dropping the link to regulator.5
[ 2.274524] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2
[ 2.282312] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.290786] ad799x 4-0029: Linked as a consumer to regulator.2
[ 2.296774] ad799x 4-0029: 4-0029 supply vref not found, using dummy regulator
[ 2.304124] ad799x 4-0029: Linked as a consumer to regulator.0
[ 2.312429] NET: Registered protocol family 10
[ 2.317545] Segment Routing with IPv6
[ 2.321263] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.327713] NET: Registered protocol family 17
[ 2.332341] Key type dns_resolver registered
[ 2.336748] Registering SWP/SWPB emulation handler
[ 2.341589] omap_voltage_late_init: Voltage driver support not added
[ 2.348043] Power Management for TI OMAP4+ devices.
[ 2.353668] Loading compiled-in X.509 certificates
[ 2.366884] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.378478] dmm 4e000000.dmm: workaround for errata i878 in use
[ 2.384604] mmc0: new high speed SDHC card at address aaaa
[ 2.386028] dmm 4e000000.dmm: initialized all PAT entries
[ 2.396454] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.15
[ 2.400734] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 2.403979] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.15
[ 2.416801] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.15
[ 2.424633] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.432694] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.440787] mmcblk0: p1 p2
[ 2.441541] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.450287] [drm] No driver support for vblank timestamp query.
[ 2.456290] [drm] Cannot find any crtc or sizes
[ 2.461503] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 2.469090] hctosys: unable to open rtc device (rtc0)
[ 2.474725] ALSA device list:
[ 2.477703] No soundcards found.
[ 2.966078] EXT4-fs (mmcblk0p2): recovery complete
[ 2.972003] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.980289] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.990346] devtmpfs: mounted
[ 2.994248] Freeing unused kernel memory: 2048K
[ 2.998898] Run /sbin/init as init process
[ 3.286947] systemd[1]: System time before build time, advancing clock.
[ 3.312495] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.334666] systemd[1]: Detected architecture arm.
Welcome to Arago 2019.11!
[ 3.391896] systemd[1]: Set hostname to <mitysom-am57x>.
[ 3.521896] [drm] Cannot find any crtc or sizes
[ 3.595454] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.612669] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.826226] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.908388] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.942245] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.975774] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.014982] systemd[1]: Starting Journal Service...
Starting Load Kernel Modules...
[ 4.071820] cmemk: loading out-of-tree module taints kernel.
[ 4.078363] CMEMK module: reference Linux version 4.19.94
[ OK ] Listening on initctl Compatibility Named Pipe[ 4.085146] allocated heap buffer 0x40500000 of size 0x100000
[ 4.096094] cmemk initialized
[ 4.117588] cryptodev: driver 1.9 loaded.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.154226] usbcore: registered new interface driver usbfs
[ 4.165200] usbcore: registered new interface driver hub
[ 4.170610] usbcore: registered new device driver usb
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.190741] usbcore: registered new interface driver ftdi_sio
[ 4.196571] usbserial: USB Serial support registered for FTDI USB Serial Device
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on udev Kernel Socket.
Starting udev Coldplug all Devices...
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Reached target Remote File Systems.
Mounting Kernel Debug File System...
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
Starting Remount Root and Kernel File Systems...
[ 4.654820] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Remount Root and Kernel File Systems.
Starting Create Static Device Nodes in /dev...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ 5.101992] systemd-journald[96]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Reached target Containers.
Starting udev Kernel Device Manager...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories[ 5.530606] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
[ 5.559434] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
[ 5.568529] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 5.579871] remoteproc remoteproc0: 58820000.ipu is available
[ 5.591707] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
[ 5.606790] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
Starting Network Time Synchronization...
Starting Network Service...
[ 5.662703] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 5.670828] remoteproc remoteproc1: 55020000.ipu is available
Starting Update UTMP about System Boot/Shutdown...
[ 5.692994] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[ 5.714800] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[ 5.723132] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 5.733106] remoteproc remoteproc2: 40800000.dsp is available
[ 5.767319] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
[ 5.778404] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
[ 5.778411] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 5.778488] remoteproc remoteproc3: 41000000.dsp is available
[ OK ] Found device /dev/ttyS2.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 6.222648] omap_gpio 48051000.gpio: Could not set line 25 debounce to 20000 microseconds (-22)
[ 6.231561] Driver for 1-wire Dallas network protocol.
[ 6.239201] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc0
[ 6.459004] remoteproc remoteproc0: powering up 58820000.ipu
[ 6.464894] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6849560
[ 6.475994] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.482570] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[ 6.484757] remoteproc remoteproc0: registered virtio0 (type 7)
[ 6.504265] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 6.613242] at24 0-0050: 4096 byte 24c32 EEPROM, read-only, 0 bytes/write
[ 6.638776] omap_rtc 48838000.rtc: registered as rtc1
[ 6.666630] at24 4-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 6.676429] tlv320aic3x-codec 4-0018: Linked as a consumer to regulator.3
[ 6.687470] tlv320aic3x-codec 4-0018: Linked as a consumer to regulator.2
[ 6.707360] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[ 6.726579] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered.
[ 6.869434] remoteproc remoteproc1: powering up 55020000.ipu
[ 6.876618] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 4808704
[ 6.902269] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 6.959768] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 6.966957] remoteproc remoteproc1: registered virtio1 (type 7)
[ 6.973682] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 6.982244] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x32
[ 6.990249] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x33
[ 6.998305] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 7.005416] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 7.023980] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 7.031154] phy phy-4a084000.phy.3: Linked as a consumer to regulator.23
[ 7.039796] phy phy-4a085000.phy.4: Linked as a consumer to regulator.23
[ OK ] Started Network Time Synchronization.
[ 7.123498] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 7.134916] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 7.140993] omap-des 480a5000.des: will run requests pump with realtime priority
[ OK ] Reached target System Initialization.
[ 7.250926] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 7.261546] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 7.274906] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 7.284501] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 7.566412] net eth1: initializing cpsw version 1.15 (0)
[ 7.578548] Generic PHY 48485000.mdio:03: attached PHY driver [Generic PHY] (mii_bus:phy_addr=48485000.mdio:03, irq=POLL)
[ 7.594672] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.604027] net eth0: initializing cpsw version 1.15 (0)
[ 7.616356] Generic PHY 48485000.mdio:02: attached PHY driver [Generic PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
[ 7.629534] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.663175] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit
[ 7.670259] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
[ 7.676065] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 7.684703] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 7.692846] ahci 4a140000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
[ 7.716557] scsi host0: ahci
[ 7.719732] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 82
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 7.781930] vpe 489d0000.vpe: Device registered as /dev/video0
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 8.053212] ata1: SATA link down (SStatus 0 SControl 300)
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 8.111406] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Job spooling tools.
[ 8.228488] remoteproc remoteproc2: powering up 40800000.dsp
[ 8.237171] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 20360572
Starting TI MultiCore Tools Daemon...
[ 8.249032] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 8.258222] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
Starting Login Service...
[ 8.286553] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.294962] remoteproc remoteproc3: powering up 41000000.dsp
[ 8.308938] remoteproc remoteproc2: registered virtio2 (type 7)
Starting Print notice about GPLv3 packages...
[ 8.325976] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20360572
Starting RPC Bind Service...
Starting rc.pvr.service...
[ 8.384337] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 8.406411] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 8.406445] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 8.413512] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 8.414567] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 8.414575] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
[ 8.515077] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 8.515126] remoteproc remoteproc3: registered virtio3 (type 7)
[ 8.515132] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[ 8.543769] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 8.566987] omap_gpio 48051000.gpio: Could not set line 24 debounce to 20000 microseconds (-22)
[ 8.587666] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[ OK ] Started Periodic Command Scheduler.
Starting TI IPC Daemon...
Starting Reboot and dump vmcore via kexec...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Started Network Service.
[ OK ] Started TI MultiCore Tools Daemon.
[ OK ] Started RPC Bind Service.
[ OK ] Started rc.pvr.service.
[ 8.771963] davinci_mdio 4b2b2400.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 8.786513] libphy: 4b2b2400.mdio: probed
[ OK ] Started TI IPC Daemon.
[ 8.816031] mdio_bus 4b2b2400.mdio: MDIO device at address 1 is missing.
[ OK ] Started Reboot and dump vmcore via kexec.
[ 8.833871] davinci_mdio 4b2b2400.mdio: phy[0]: device 4b2b2400.mdio:00, driver unknown
[ 8.848948] asoc-simple-card sound0: tlv320aic3x-hifi <-> 4847c000.mcasp mapping ok
[ 8.868993] asoc-simple-card sound0: ASoC: no DMI vendor name!
[ 8.883726] remoteproc remoteproc4: 4b234000.pru is available
[ 8.902154] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed successfully
[ 8.944316] remoteproc remoteproc5: 4b238000.pru is available
[ 8.960979] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed successfully
[ 8.985712] remoteproc remoteproc6: 4b2b4000.pru is available
[ 9.003466] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed successfully
[ 9.034419] remoteproc remoteproc7: 4b2b8000.pru is available
[ 9.075090] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed successfully
[ 9.158527] prueth pruss2_eth: port 1: using random MAC addr: 3e:dc:db:21:ab:b6
[ 9.255283] prueth pruss2_eth: port 2: using random MAC addr: 06:9a:01:89:65:92
[ 9.311967] prueth pruss2_eth: freeing port 0
[ 9.350939] prueth pruss2_eth: port 1: using random MAC addr: e2:f6:a1:5a:5f:01
[ 9.380122] prueth pruss2_eth: port 2: using random MAC addr: 82:f0:8e:e2:94:73
[ 9.450335] prueth pruss2_eth: freeing port 0
[ 9.482473] prueth pruss2_eth: port 1: using random MAC addr: 26:87:ba:7a:58:25
[ 9.567327] prueth pruss2_eth: port 2: using random MAC addr: 42:b3:79:87:b3:8b
[ 9.615414] prueth pruss2_eth: freeing port 0
[ 9.643951] prueth pruss2_eth: port 1: using random MAC addr: b6:8a:7b:82:bb:7d
[ 9.699979] prueth pruss2_eth: port 2: using random MAC addr: 5a:1c:66:7e:e2:db
[ 9.748369] prueth pruss2_eth: freeing port 0
[ 9.774566] prueth pruss2_eth: port 1: using random MAC addr: 96:32:76:36:df:08
[ 9.812001] prueth pruss2_eth: port 2: using random MAC addr: 56:30:60:1e:48:59
[ 9.846907] prueth pruss2_eth: freeing port 0
[ 9.868832] prueth pruss2_eth: port 1: using random MAC addr: a6:6c:02:08:53:56
[ 9.899144] prueth pruss2_eth: port 2: using random MAC addr: 4a:c1:bd:9a:e1:01
[ 9.924026] prueth pruss2_eth: freeing port 0
[ 9.946882] prueth pruss2_eth: port 1: using random MAC addr: de:50:91:5b:91:56
[ 9.973942] prueth pruss2_eth: port 2: using random MAC addr: 22:a2:f5:3a:b2:8f
[ 9.996221] prueth pruss2_eth: freeing port 0
[ 10.016498] prueth pruss2_eth: port 1: using random MAC addr: ca:d2:58:53:02:aa
[ 10.045554] prueth pruss2_eth: port 2: using random MAC addr: c2:9c:f0:80:22:7d
[ 10.070598] prueth pruss2_eth: freeing port 0
[ 10.090934] prueth pruss2_eth: port 1: using random MAC addr: d6:86:b8:0c:64:2e
[ 10.120049] prueth pruss2_eth: port 2: using random MAC addr: 1e:c3:e6:1b:e3:b8
[ 10.148807] prueth pruss2_eth: freeing port 0
[ 10.175163] prueth pruss2_eth: port 1: using random MAC addr: 12:11:90:89:8e:fc
[ 10.208424] prueth pruss2_eth: port 2: using random MAC addr: f2:88:9e:24:d2:e7
[ 10.226985] prueth pruss2_eth: freeing port 0
[ 10.265711] prueth pruss2_eth: port 1: using random MAC addr: da:80:99:db:af:18
[ 10.288411] prueth pruss2_eth: port 2: using random MAC addr: 22:bf:cb:c1:2f:43
[ 10.352989] prueth pruss2_eth: freeing port 0
[ 10.369791] prueth pruss2_eth: port 1: using random MAC addr: 9a:d5:fa:7e:25:1d
[ 10.400724] prueth pruss2_eth: port 2: using random MAC addr: 3a:9a:20:11:43:0c
[ 10.424788] prueth pruss2_eth: freeing port 0
[ 10.438592] prueth pruss2_eth: port 1: using random MAC addr: 0e:1e:24:6e:99:6b
[ 10.462705] dwc3 48890000.usb: Failed to get clk 'ref': -2
[ 10.462715] prueth pruss2_eth: port 2: using random MAC addr: ce:1b:cf:27:29:ea
[ 10.510878] prueth pruss2_eth: freeing port 0
[ 10.515527] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service rpc_example_1 with src 1024 dst 101
[ 10.527166] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[ 10.527486] prueth pruss2_eth: port 1: using random MAC addr: ea:2e:6d:e5:64:72
[ 10.576225] dwc3 48890000.usb: changing max_speed on rev 5533202a
[ 10.583701] prueth pruss2_eth: port 2: using random MAC addr: ba:60:e2:78:99:71
[ 10.594369] prueth pruss2_eth: freeing port 0
[ 10.599773] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 8
[ 10.611561] prueth pruss2_eth: port 1: using random MAC addr: a6:db:a3:83:88:e6
[ 10.641538] prueth pruss2_eth: port 2: using random MAC addr: ca:89:dc:7a:03:33
[ 10.650376] NET: Registered protocol family 45
[ 10.666966] prueth pruss2_eth: freeing port 0
[ 10.695267] prueth pruss2_eth: port 1: using random MAC addr: 5e:1e:3d:e9:8f:ca
[ 10.766599] prueth pruss2_eth: port 2: using random MAC addr: a2:77:d0:11:d9:f6
[ 10.798108] prueth pruss2_eth: freeing port 0
[ 10.820338] prueth pruss2_eth: port 1: using random MAC addr: ba:ee:64:2d:ba:db
[ 10.847092] prueth pruss2_eth: port 2: using random MAC addr: 56:33:71:ee:38:df
[ 10.859315] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 10.865098] prueth pruss2_eth: freeing port 0
[ 10.871819] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 10.884364] prueth pruss2_eth: port 1: using random MAC addr: de:8a:d3:14:cf:59
[ 10.893954] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ 10.894108] prueth pruss2_eth: port 2: using random MAC addr: 0e:9f:e9:07:cc:d9
[ 10.919880] xhci-hcd xhci-hcd.1.auto: irq 197, io mem 0x488d0000
[ 10.931413] prueth pruss2_eth: freeing port 0
[ 10.933712] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 10.947903] prueth pruss2_eth: port 1: using random MAC addr: 2a:38:78:cd:58:ae
[ 10.952612] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.962705] usb usb1: Product: xHCI Host Controller
[ 10.964364] prueth pruss2_eth: port 2: using random MAC addr: 6a:85:fe:6b:ab:54
[ 10.970023] usb usb1: Manufacturer: Linux 4.19.94-g7317dfbd4116-dirty xhci-hcd
[ 10.982518] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 10.987653] prueth pruss2_eth: freeing port 0
[ 10.988573] hub 1-0:1.0: USB hub found
[ 10.996020] hub 1-0:1.0: 1 port detected
[ 11.001777] prueth pruss2_eth: port 1: using random MAC addr: d6:c2:cb:2f:04:44
[ 11.003389] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.017321] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 11.023079] prueth pruss2_eth: port 2: using random MAC addr: 7e:fa:12:f4:c8:d4
[ 11.025319] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 11.035745] prueth pruss2_eth: freeing port 0
[ 11.039959] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 11.046158] prueth pruss2_eth: port 1: using random MAC addr: 5a:31:d4:3a:0e:15
[ 11.052885] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 11.064029] prueth pruss2_eth: port 2: using random MAC addr: 4e:f9:74:ee:a8:c2
[ 11.069102] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.075295] prueth pruss2_eth: freeing port 0
[ 11.081848] usb usb2: Product: xHCI Host Controller
[ 11.088177] prueth pruss2_eth: port 1: using random MAC addr: 16:74:43:4d:70:26
[ 11.100835] usb usb2: Manufacturer: Linux 4.19.94-g7317dfbd4116-dirty xhci-hcd
[ 11.109316] prueth pruss2_eth: port 2: using random MAC addr: 1e:34:e8:ad:98:93
[ 11.113484] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 11.124348] prueth pruss2_eth: freeing port 0
[ 11.124577] hub 2-0:1.0: USB hub found
[ 11.138911] prueth pruss2_eth: port 1: using random MAC addr: fe:8c:2d:14:29:2c
[ 11.142861] hub 2-0:1.0: 1 port detected
[ 11.159013] prueth pruss2_eth: port 2: using random MAC addr: ce:5b:d7:0e:77:45
[ 11.173842] prueth pruss2_eth: freeing port 0
[ 11.191408] prueth pruss2_eth: port 1: using random MAC addr: 5e:dd:a6:97:f7:4c
[ 11.211883] prueth pruss2_eth: port 2: using random MAC addr: 7e:1a:72:52:03:d1
[ 11.219425] prueth pruss2_eth: freeing port 0
[ 11.226635] prueth pruss2_eth: port 1: using random MAC addr: 26:e1:67:67:63:ae
[ 11.235506] prueth pruss2_eth: port 2: using random MAC addr: d6:3c:58:71:5a:61
[ 11.243696] prueth pruss2_eth: freeing port 0
[ 11.250985] prueth pruss2_eth: port 1: using random MAC addr: f2:4a:3d:a0:ef:b9
[ 11.270687] prueth pruss2_eth: port 2: using random MAC addr: 1a:ed:6e:5e:20:db
[ 11.278413] prueth pruss2_eth: freeing port 0
[ 11.286656] prueth pruss2_eth: port 1: using random MAC addr: 06:ba:b1:21:80:1c
[ 11.299223] prueth pruss2_eth: port 2: using random MAC addr: a2:c2:1b:7d:8b:2a
[ 11.310928] prueth pruss2_eth: freeing port 0
[ 11.318312] prueth pruss2_eth: port 1: using random MAC addr: 6e:b8:61:8c:bd:72
[ 11.327570] prueth pruss2_eth: port 2: using random MAC addr: 3a:60:ff:1e:55:01
[ 11.335133] prueth pruss2_eth: freeing port 0
[ 11.341179] prueth pruss2_eth: port 1: using random MAC addr: 2e:ce:3b:56:09:70
[ 11.350908] prueth pruss2_eth: port 2: using random MAC addr: fe:e1:32:bb:83:da
[ 11.359189] prueth pruss2_eth: freeing port 0
[ 11.365967] prueth pruss2_eth: port 1: using random MAC addr: 2e:8d:dd:20:39:ed
[ 11.374812] prueth pruss2_eth: port 2: using random MAC addr: a6:7e:98:7c:ab:1c
[ 11.382775] prueth pruss2_eth: freeing port 0
[ 11.393301] prueth pruss2_eth: port 1: using random MAC addr: 1e:6e:7b:9a:6f:07
[ 11.406365] prueth pruss2_eth: port 2: using random MAC addr: f6:eb:a9:e6:52:7f
[ 11.416664] prueth pruss2_eth: freeing port 0
[ 11.426885] prueth pruss2_eth: port 1: using random MAC addr: fa:a4:20:75:e1:20
[ 11.439458] prueth pruss2_eth: port 2: using random MAC addr: 5e:b3:53:86:04:2b
[ 11.450477] prueth pruss2_eth: freeing port 0
[ 11.458062] prueth pruss2_eth: port 1: using random MAC addr: 42:ec:35:b9:f1:3e
[ 11.466424] prueth pruss2_eth: port 2: using random MAC addr: 92:92:8b:a5:d1:b8
[ 11.475348] prueth pruss2_eth: freeing port 0
[ 11.482014] prueth pruss2_eth: port 1: using random MAC addr: 5a:fc:00:a4:84:fa
[ 11.491186] prueth pruss2_eth: port 2: using random MAC addr: 32:76:b7:cf:65:43
[ 11.498797] prueth pruss2_eth: freeing port 0
[ 11.505888] prueth pruss2_eth: port 1: using random MAC addr: 4e:ec:30:5a:79:10
[ 11.514839] prueth pruss2_eth: port 2: using random MAC addr: 1a:12:da:16:d3:47
[ 11.523662] prueth pruss2_eth: freeing port 0
[ 11.530949] prueth pruss2_eth: port 1: using random MAC addr: 2a:11:af:40:b7:34
[ 11.544960] prueth pruss2_eth: port 2: using random MAC addr: 06:88:72:49:b2:91
[ 11.554472] prueth pruss2_eth: freeing port 0
[ 11.563129] prueth pruss2_eth: port 1: using random MAC addr: 5a:5d:f3:0e:2e:13
[ 11.572670] prueth pruss2_eth: port 2: using random MAC addr: de:cd:1a:f5:6c:12
[ 11.580241] prueth pruss2_eth: freeing port 0
[ 11.592448] prueth pruss2_eth: port 1: using random MAC addr: a2:45:2f:40:1b:3a
[ 11.601638] prueth pruss2_eth: port 2: using random MAC addr: 7e:3d:25:b5:36:c3
[ 11.613432] prueth pruss2_eth: freeing port 0
[ 11.624135] prueth pruss2_eth: port 1: using random MAC addr: 7e:7d:e5:81:62:13
[ 11.633151] prueth pruss2_eth: port 2: using random MAC addr: 4a:4e:51:85:73:56
[ 11.640748] prueth pruss2_eth: freeing port 0
[ 11.648061] prueth pruss2_eth: port 1: using random MAC addr: fe:6c:b4:09:26:89
[ 11.657649] prueth pruss2_eth: port 2: using random MAC addr: 4e:bb:b0:7b:fb:58
[ 11.665253] prueth pruss2_eth: freeing port 0
[ 11.672781] prueth pruss2_eth: port 1: using random MAC addr: 2e:a4:da:e8:a4:d3
[ 11.681967] prueth pruss2_eth: port 2: using random MAC addr: c2:67:21:d0:cf:db
[ 11.689543] prueth pruss2_eth: freeing port 0
[ 11.696889] prueth pruss2_eth: port 1: using random MAC addr: d2:89:82:96:37:b6
[ 11.706045] prueth pruss2_eth: port 2: using random MAC addr: fa:95:b6:92:db:7d
[ 11.713638] prueth pruss2_eth: freeing port 0
[ 11.720907] prueth pruss2_eth: port 1: using random MAC addr: d6:95:b4:33:8f:4a
[ 11.730137] prueth pruss2_eth: port 2: using random MAC addr: 0a:90:4b:4f:61:08
[ 11.737762] prueth pruss2_eth: freeing port 0
[ 11.745094] prueth pruss2_eth: port 1: using random MAC addr: 5a:a9:c5:92:29:61
[ 11.756102] prueth pruss2_eth: port 2: using random MAC addr: 1e:68:84:1e:18:85
[ 11.764370] prueth pruss2_eth: freeing port 0
[ 11.774594] prueth pruss2_eth: port 1: using random MAC addr: c2:a4:c2:53:af:3a
[ 11.783808] prueth pruss2_eth: port 2: using random MAC addr: 32:32:34:75:6c:a3
[ 11.791344] prueth pruss2_eth: freeing port 0
[ 11.798774] prueth pruss2_eth: port 1: using random MAC addr: ae:eb:e2:26:50:ea
[ 11.812752] prueth pruss2_eth: port 2: using random MAC addr: 8a:71:89:58:d3:4c
[ 11.820287] prueth pruss2_eth: freeing port 0
[ 11.827865] prueth pruss2_eth: port 1: using random MAC addr: 0e:66:fc:b9:21:27
[ 11.836335] prueth pruss2_eth: port 2: using random MAC addr: 56:13:cb:4a:a2:ab
[ 11.845254] prueth pruss2_eth: freeing port 0
[ 11.852431] prueth pruss2_eth: port 1: using random MAC addr: fe:93:a3:35:84:41
[ 11.861619] prueth pruss2_eth: port 2: using random MAC addr: fa:13:d0:5f:b2:43
[ 11.873811] prueth pruss2_eth: freeing port 0
[ 11.882330] prueth pruss2_eth: port 1: using random MAC addr: 92:80:f2:ca:fc:4d
[ 11.891412] prueth pruss2_eth: port 2: using random MAC addr: 2e:41:47:32:57:5c
[ 11.903388] prueth pruss2_eth: freeing port 0
[ 11.911628] prueth pruss2_eth: port 1: using random MAC addr: 7a:15:fb:4b:fd:2e
[ 11.921580] prueth pruss2_eth: port 2: using random MAC addr: 82:d3:04:16:e3:f4
[ 11.929214] prueth pruss2_eth: freeing port 0
[ 11.936859] prueth pruss2_eth: port 1: using random MAC addr: 0a:28:f5:01:e4:a6
[ 11.945905] prueth pruss2_eth: port 2: using random MAC addr: 5a:fb:b3:73:b6:41
[ 11.953566] prueth pruss2_eth: freeing port 0
[ 11.960775] prueth pruss2_eth: port 1: using random MAC addr: 7e:e2:49:96:8d:43
[ 11.970026] prueth pruss2_eth: port 2: using random MAC addr: ca:8f:14:2e:d7:03
[ 11.977663] prueth pruss2_eth: freeing port 0
[ 11.985056] prueth pruss2_eth: port 1: using random MAC addr: a6:11:ca:f9:34:c1
[ 11.993501] prueth pruss2_eth: port 2: using random MAC addr: 76:03:01:b8:d7:03
[ 12.002333] prueth pruss2_eth: freeing port 0
[ 12.009114] prueth pruss2_eth: port 1: using random MAC addr: 5e:68:01:c9:61:b1
[ 12.018384] prueth pruss2_eth: port 2: using random MAC addr: 6a:91:77:4b:44:1f
[ 12.026015] prueth pruss2_eth: freeing port 0
[ 12.033224] prueth pruss2_eth: port 1: using random MAC addr: f2:68:50:4d:d0:dd
[ 12.042394] prueth pruss2_eth: port 2: using random MAC addr: 8e:02:7c:50:67:28
[ 12.053521] prueth pruss2_eth: freeing port 0
[ 12.061713] prueth pruss2_eth: port 1: using random MAC addr: 96:fc:54:58:8a:a2
[ 12.071134] prueth pruss2_eth: port 2: using random MAC addr: 9a:6d:09:29:64:c0
[ 12.078812] prueth pruss2_eth: freeing port 0
[ 12.086175] prueth pruss2_eth: port 1: using random MAC addr: 22:06:8b:f0:07:cc
[ 12.095399] prueth pruss2_eth: port 2: using random MAC addr: ce:ae:01:9f:3a:21
[ 12.103044] prueth pruss2_eth: freeing port 0
[ 12.110256] prueth pruss2_eth: port 1: using random MAC addr: 3a:ac:db:de:62:21
[ 12.119375] prueth pruss2_eth: port 2: using random MAC addr: be:bb:ff:4f:28:e8
[ 12.131630] prueth pruss2_eth: freeing port 0
[ 12.138955] prueth pruss2_eth: port 1: using random MAC addr: e6:8e:25:93:06:b7
[ 12.148633] prueth pruss2_eth: port 2: using random MAC addr: 2e:f6:f0:e3:db:72
[ 12.160378] prueth pruss2_eth: freeing port 0
[ 12.168889] prueth pruss2_eth: port 1: using random MAC addr: 0a:fb:ea:b0:82:62
[ 12.178036] prueth pruss2_eth: port 2: using random MAC addr: 16:1a:99:1c:67:a3
[ 12.189841] prueth pruss2_eth: freeing port 0
[ 12.198301] prueth pruss2_eth: port 1: using random MAC addr: 6e:eb:2a:03:7e:af
[ 12.207733] prueth pruss2_eth: port 2: using random MAC addr: 3e:57:aa:31:e5:75
[ 12.215463] prueth pruss2_eth: freeing port 0
[ 12.222777] prueth pruss2_eth: port 1: using random MAC addr: ba:41:19:73:41:c2
[ 12.231261] prueth pruss2_eth: port 2: using random MAC addr: 76:4e:09:06:1c:8f
[ 12.238935] prueth pruss2_eth: freeing port 0
[ 12.245104] prueth pruss2_eth: port 1: using random MAC addr: d2:a1:da:c3:3a:30
[ 12.253687] prueth pruss2_eth: port 2: using random MAC addr: 62:f9:95:30:94:0b
[ 12.261244] prueth pruss2_eth: freeing port 0
[ 12.267457] prueth pruss2_eth: port 1: using random MAC addr: 46:68:3c:42:d0:2a
[ 12.280543] prueth pruss2_eth: port 2: using random MAC addr: 22:97:2b:1d:4c:ca
[ 12.290809] prueth pruss2_eth: freeing port 0
[ 12.299235] prueth pruss2_eth: port 1: using random MAC addr: 56:6c:66:03:1e:7f
[ 12.307765] prueth pruss2_eth: port 2: using random MAC addr: f6:d0:84:46:bd:53
[ 12.315535] prueth pruss2_eth: freeing port 0
[ 12.321684] prueth pruss2_eth: port 1: using random MAC addr: 1a:cb:18:dc:b2:2d
[ 12.330241] prueth pruss2_eth: port 2: using random MAC addr: 36:5f:6c:32:2e:45
[ 12.337859] prueth pruss2_eth: freeing port 0
[ 12.344040] prueth pruss2_eth: port 1: using random MAC addr: 26:11:d4:8b:8b:8f
[ 12.354901] prueth pruss2_eth: port 2: using random MAC addr: 7a:c0:3a:11:48:34
[ 12.362513] prueth pruss2_eth: freeing port 0
[ 12.368681] prueth pruss2_eth: port 1: using random MAC addr: f6:89:94:5a:59:80
[ 12.381775] prueth pruss2_eth: port 2: using random MAC addr: 46:9b:36:44:92:e9
[ 12.389326] prueth pruss2_eth: freeing port 0
[ 12.395994] prueth pruss2_eth: port 1: using random MAC addr: ce:47:e6:96:62:c3
[ 12.404506] prueth pruss2_eth: port 2: using random MAC addr: b6:bd:11:e6:4b:4e
[ 12.418067] prueth pruss2_eth: freeing port 0
[ 12.424451] prueth pruss2_eth: port 1: using random MAC addr: ca:63:55:ef:92:d3
[ 12.437553] prueth pruss2_eth: port 2: using random MAC addr: 7a:1a:7d:63:3b:aa
[ 12.448199] prueth pruss2_eth: freeing port 0
[ 12.455398] prueth pruss2_eth: port 1: using random MAC addr: 36:51:fc:ea:02:5a
[ 12.464188] prueth pruss2_eth: port 2: using random MAC addr: d2:89:86:34:de:91
[ 12.471801] prueth pruss2_eth: freeing port 0
[ 12.477965] prueth pruss2_eth: port 1: using random MAC addr: 86:26:26:1e:71:e6
[ 12.491169] prueth pruss2_eth: port 2: using random MAC addr: 26:57:25:bf:2b:7e
[ 12.498739] prueth pruss2_eth: freeing port 0
[ 12.504896] prueth pruss2_eth: port 1: using random MAC addr: a2:be:70:77:67:b4
[ 12.513420] prueth pruss2_eth: port 2: using random MAC addr: 2e:cd:09:1f:c4:f3
[ 12.524521] prueth pruss2_eth: freeing port 0
[ 12.531701] prueth pruss2_eth: port 1: using random MAC addr: be:54:9c:29:2e:a1
[ 12.540225] prueth pruss2_eth: port 2: using random MAC addr: ea:9b:78:b8:9b:4a
[ 12.547838] prueth pruss2_eth: freeing port 0
[ 12.553992] prueth pruss2_eth: port 1: using random MAC addr: 76:6f:a2:74:a8:32
[ 12.563031] prueth pruss2_eth: port 2: using random MAC addr: f2:e4:fd:9b:8c:36
[ 12.572738] prueth pruss2_eth: freeing port 0
[ 12.581681] prueth pruss2_eth: port 1: using random MAC addr: 4a:68:ef:d4:5e:0a
[ 12.590133] prueth pruss2_eth: port 2: using random MAC addr: a2:da:51:3d:71:98
[ 12.597783] prueth pruss2_eth: freeing port 0
[ 12.603919] prueth pruss2_eth: port 1: using random MAC addr: 3a:92:c2:1e:3c:e9
[ 12.612589] prueth pruss2_eth: port 2: using random MAC addr: 86:57:a0:65:3e:e9
[ 12.620177] prueth pruss2_eth: freeing port 0
[ 12.626418] prueth pruss2_eth: port 1: using random MAC addr: fe:fd:16:6c:19:5e
[ 12.637435] prueth pruss2_eth: port 2: using random MAC addr: 02:69:aa:7d:d9:7f
[ 12.645078] prueth pruss2_eth: freeing port 0
[ 12.651231] prueth pruss2_eth: port 1: using random MAC addr: 06:b2:b9:2e:fd:50
[ 12.664310] prueth pruss2_eth: port 2: using random MAC addr: ee:fe:98:05:55:55
[ 12.671939] prueth pruss2_eth: freeing port 0
[ 12.678115] prueth pruss2_eth: port 1: using random MAC addr: 6a:22:5d:c4:e4:5c
[ 12.691203] prueth pruss2_eth: port 2: using random MAC addr: 46:03:23:07:a9:66
[ 12.698837] prueth pruss2_eth: freeing port 0
[ 12.706130] prueth pruss2_eth: port 1: using random MAC addr: 32:3e:2c:3d:89:0d
[ 12.714621] prueth pruss2_eth: port 2: using random MAC addr: 46:90:5c:2d:95:48
[ 12.722305] prueth pruss2_eth: freeing port 0
[ 12.728422] prueth pruss2_eth: port 1: using random MAC addr: 26:20:24:c5:72:37
[ 12.736926] prueth pruss2_eth: port 2: using random MAC addr: 62:96:d3:1e:00:2d
[ 12.744550] prueth pruss2_eth: freeing port 0
[ 12.750649] prueth pruss2_eth: port 1: using random MAC addr: ca:ac:71:54:eb:89
[ 12.759113] prueth pruss2_eth: port 2: using random MAC addr: f6:8a:46:66:33:d4
[ 12.766743] prueth pruss2_eth: freeing port 0
[ 12.772889] prueth pruss2_eth: port 1: using random MAC addr: 62:4a:f4:13:49:35
[ 12.781254] prueth pruss2_eth: port 2: using random MAC addr: 12:55:e7:b3:20:39
[ 12.788902] prueth pruss2_eth: freeing port 0
[ 12.795053] prueth pruss2_eth: port 1: using random MAC addr: 36:64:63:c1:da:25
[ 12.803511] prueth pruss2_eth: port 2: using random MAC addr: 22:e9:35:9e:71:47
[ 12.811095] prueth pruss2_eth: freeing port 0
[ 12.817243] prueth pruss2_eth: port 1: using random MAC addr: 1a:6e:6b:76:c6:15
[ 12.825632] prueth pruss2_eth: port 2: using random MAC addr: aa:8e:fa:2a:b5:09
[ 12.833225] prueth pruss2_eth: freeing port 0
[ 12.839349] prueth pruss2_eth: port 1: using random MAC addr: 1e:e8:80:4c:36:36
[ 12.847780] prueth pruss2_eth: port 2: using random MAC addr: 56:b5:cc:16:d5:dc
[ 12.855590] prueth pruss2_eth: freeing port 0
[ 12.861772] prueth pruss2_eth: port 1: using random MAC addr: aa:f6:a1:a8:69:ba
[ 12.870228] prueth pruss2_eth: port 2: using random MAC addr: c6:37:ff:9f:bd:73
[ 12.877884] prueth pruss2_eth: freeing port 0
[ 12.884378] prueth pruss2_eth: port 1: using random MAC addr: ce:4b:82:85:e1:a5
[ 12.892803] prueth pruss2_eth: port 2: using random MAC addr: de:6e:d3:f7:df:72
[ 12.900429] prueth pruss2_eth: freeing port 0
[ 12.906902] prueth pruss2_eth: port 1: using random MAC addr: be:93:8a:2f:2e:42
[ 12.915362] prueth pruss2_eth: port 2: using random MAC addr: c6:2b:b8:d3:85:ae
[ 12.922998] prueth pruss2_eth: freeing port 0
[ 12.929139] prueth pruss2_eth: port 1: using random MAC addr: 72:7c:64:d6:0a:b2
[ 12.937726] prueth pruss2_eth: port 2: using random MAC addr: 96:fe:0d:06:4d:cf
[ 12.945359] prueth pruss2_eth: freeing port 0
[ 12.951469] prueth pruss2_eth: port 1: using random MAC addr: a6:b5:e0:6e:5c:bd
[ 12.959938] prueth pruss2_eth: port 2: using random MAC addr: 2a:e3:a3:9f:f5:d1
[ 12.967591] prueth pruss2_eth: freeing port 0
[ 12.973749] prueth pruss2_eth: port 1: using random MAC addr: 12:5c:c8:47:fb:05
[ 12.984111] prueth pruss2_eth: port 2: using random MAC addr: be:1c:12:e4:62:9f
[ 12.992035] prueth pruss2_eth: freeing port 0
[ 13.000892] prueth pruss2_eth: port 1: using random MAC addr: 3a:f0:9a:ca:eb:c5
[ 13.009307] prueth pruss2_eth: port 2: using random MAC addr: 5e:1a:ea:80:50:87
[ 13.016937] prueth pruss2_eth: freeing port 0
[ 13.023174] prueth pruss2_eth: port 1: using random MAC addr: be:51:a8:bc:1c:cc
[ 13.031578] prueth pruss2_eth: port 2: using random MAC addr: be:4a:41:94:02:7d
[ 13.039219] prueth pruss2_eth: freeing port 0
[ 13.045482] prueth pruss2_eth: port 1: using random MAC addr: 1e:40:f5:a4:4d:51
[ 13.056555] prueth pruss2_eth: port 2: using random MAC addr: 5e:5c:48:ce:eb:af
[ 13.064135] prueth pruss2_eth: freeing port 0
[ 13.070243] prueth pruss2_eth: port 1: using random MAC addr: 22:ce:1e:4c:99:b4
[ 13.078821] prueth pruss2_eth: port 2: using random MAC addr: 46:26:33:ea:43:14
[ 13.086441] prueth pruss2_eth: freeing port 0
[ 13.092571] prueth pruss2_eth: port 1: using random MAC addr: 9a:e9:cb:a8:13:09
[ 13.105817] prueth pruss2_eth: port 2: using random MAC addr: 62:06:d6:95:b0:cd
[ 13.113437] prueth pruss2_eth: freeing port 0
[ 13.119596] prueth pruss2_eth: port 1: using random MAC addr: 6a:fe:62:41:fe:db
[ 13.132435] prueth pruss2_eth: port 2: using random MAC addr: 92:11:7a:03:2c:04
[ 13.142814] prueth pruss2_eth: freeing port 0
[ 13.150849] prueth pruss2_eth: port 1: using random MAC addr: 8e:e8:7d:b6:38:1a
[ 13.162850] prueth pruss2_eth: port 2: using random MAC addr: e6:90:ec:de:af:c2
[ 13.171306] prueth pruss2_eth: freeing port 0
[ 13.177530] prueth pruss2_eth: port 1: using random MAC addr: 22:9c:8f:65:f0:cb
[ 13.186033] prueth pruss2_eth: port 2: using random MAC addr: 06:77:35:a0:e5:3a
[ 13.197116] prueth pruss2_eth: freeing port 0
[ 13.204454] prueth pruss2_eth: port 1: using random MAC addr: 3a:db:db:eb:98:e9
[ 13.213009] prueth pruss2_eth: port 2: using random MAC addr: ca:f0:51:61:36:6a
[ 13.220588] prueth pruss2_eth: freeing port 0
[ 13.226781] prueth pruss2_eth: port 1: using random MAC addr: ee:89:ad:65:f5:37
[ 13.235282] prueth pruss2_eth: port 2: using random MAC addr: 02:1e:57:f6:56:32
[ 13.242982] prueth pruss2_eth: freeing port 0
[ 13.249189] prueth pruss2_eth: port 1: using random MAC addr: 4a:5c:c9:53:22:ff
[ 13.257775] prueth pruss2_eth: port 2: using random MAC addr: 4e:9b:3b:30:f7:f4
[ 13.265363] prueth pruss2_eth: freeing port 0
[ 13.271453] prueth pruss2_eth: port 1: using random MAC addr: 2a:de:5f:fc:2c:5f
[ 13.280063] prueth pruss2_eth: port 2: using random MAC addr: aa:34:4a:61:1b:11
[ 13.287683] prueth pruss2_eth: freeing port 0
[ 13.293892] prueth pruss2_eth: port 1: using random MAC addr: 1e:3e:3c:ad:92:cb
[ 13.302278] prueth pruss2_eth: port 2: using random MAC addr: 8e:32:d3:a3:84:d8
[ 13.316018] prueth pruss2_eth: freeing port 0
[ 13.321682] prueth pruss2_eth: port 1: using random MAC addr: 9e:31:cb:af:07:d3
[ 13.329887] prueth pruss2_eth: port 2: using random MAC addr: 9e:37:fa:12:07:21
[ 13.337316] prueth pruss2_eth: freeing port 0
[ 13.343270] prueth pruss2_eth: port 1: using random MAC addr: 76:1f:68:d6:6d:1b
[ 13.353546] prueth pruss2_eth: port 2: using random MAC addr: 86:7a:8f:24:a4:03
[ 13.362484] prueth pruss2_eth: freeing port 0
[ 13.369081] prueth pruss2_eth: port 1: using random MAC addr: d6:02:74:04:c8:7e
[ 13.377525] prueth pruss2_eth: port 2: using random MAC addr: c6:a5:5b:64:78:bc
[ 13.384911] prueth pruss2_eth: freeing port 0
[ 13.390467] prueth pruss2_eth: port 1: using random MAC addr: 42:d3:22:71:4e:e0
[ 13.398712] prueth pruss2_eth: port 2: using random MAC addr: b2:61:46:4b:ca:2d
[ 13.406169] prueth pruss2_eth: freeing port 0
[ 13.411840] prueth pruss2_eth: port 1: using random MAC addr: 06:79:96:a6:eb:3e
[ 13.420023] prueth pruss2_eth: port 2: using random MAC addr: ae:74:7f:02:b5:ed
[ 13.430506] prueth pruss2_eth: freeing port 0
[ 13.438183] prueth pruss2_eth: port 1: using random MAC addr: 82:68:55:63:c8:e2
[ 13.448291] prueth pruss2_eth: port 2: using random MAC addr: 9e:52:07:e0:d7:cc
[ 13.455948] prueth pruss2_eth: freeing port 0
[ 13.462116] prueth pruss2_eth: port 1: using random MAC addr: 7a:c2:aa:d0:d1:24
[ 13.470641] prueth pruss2_eth: port 2: using random MAC addr: da:f6:41:d9:97:1c
[ 13.478351] prueth pruss2_eth: freeing port 0
[ 13.484540] prueth pruss2_eth: port 1: using random MAC addr: 5a:e3:d3:22:46:01
[ 13.497621] prueth pruss2_eth: port 2: using random MAC addr: d6:c8:7f:ca:f3:34
[ 13.505231] prueth pruss2_eth: freeing port 0
[ 13.511416] prueth pruss2_eth: port 1: using random MAC addr: 6e:c4:86:a9:b7:02
[ 13.524539] prueth pruss2_eth: port 2: using random MAC addr: 8a:0f:fa:56:2d:cf
[ 13.532186] prueth pruss2_eth: freeing port 0
[ 13.538390] prueth pruss2_eth: port 1: using random MAC addr: 46:24:01:55:4d:01
[ 13.551507] prueth pruss2_eth: port 2: using random MAC addr: 16:8b:14:23:99:cc
[ 13.559168] prueth pruss2_eth: freeing port 0
[ 13.565404] prueth pruss2_eth: port 1: using random MAC addr: 02:54:69:4a:bf:43
[ 13.578693] prueth pruss2_eth: port 2: using random MAC addr: 4a:12:a9:be:7f:b0
[ 13.586335] prueth pruss2_eth: freeing port 0
[ 13.592807] prueth pruss2_eth: port 1: using random MAC addr: 66:43:43:a8:29:1a
[ 13.607644] prueth pruss2_eth: port 2: using random MAC addr: 0e:d2:0f:ec:b9:51
[ 13.621465] prueth pruss2_eth: freeing port 0
[ 13.627869] prueth pruss2_eth: port 1: using random MAC addr: 1e:bc:ad:1e:49:fd
[ 13.640976] prueth pruss2_eth: port 2: using random MAC addr: 02:bd:c3:4d:73:a5
[ 13.652489] prueth pruss2_eth: freeing port 0
[ 13.659254] prueth pruss2_eth: port 1: using random MAC addr: 96:10:d9:17:e6:b3
[ 13.671571] prueth pruss2_eth: port 2: using random MAC addr: 1a:4f:d6:3d:28:9d
[ 13.679057] prueth pruss2_eth: freeing port 0
[ 13.691206] prueth pruss2_eth: port 1: using random MAC addr: 9e:cc:04:a7:1d:be
[ 13.701535] prueth pruss2_eth: port 2: using random MAC addr: ce:57:f0:8c:fb:72
[ 13.711278] prueth pruss2_eth: freeing port 0
[ 13.716943] prueth pruss2_eth: port 1: using random MAC addr: c2:1e:42:48:54:ac
[ 13.729708] prueth pruss2_eth: port 2: using random MAC addr: fa:32:90:e6:58:82
[ 13.743440] prueth pruss2_eth: freeing port 0
[ 13.749584] prueth pruss2_eth: port 1: using random MAC addr: da:31:f0:a2:bd:b5
[ 13.762967] prueth pruss2_eth: port 2: using random MAC addr: 0e:8e:30:22:18:df
[ 13.770323] prueth pruss2_eth: freeing port 0
[ 13.781832] prueth pruss2_eth: port 1: using random MAC addr: 46:c1:92:ca:fa:c2
[ 13.793142] prueth pruss2_eth: port 2: using random MAC addr: 5e:f6:88:22:91:41
[ 13.800505] prueth pruss2_eth: freeing port 0
[ 13.810191] prueth pruss2_eth: port 1: using random MAC addr: 9e:99:25:35:59:48
[ 13.821895] prueth pruss2_eth: port 2: using random MAC addr: 8e:c9:03:16:55:86
[ 13.832408] prueth pruss2_eth: freeing port 0
[ 13.838947] prueth pruss2_eth: port 1: using random MAC addr: 2a:f1:8f:95:cb:90
[ 13.853899] prueth pruss2_eth: port 2: using random MAC addr: d6:8e:eb:d0:65:4e
[ 13.861261] prueth pruss2_eth: freeing port 0
