Part Number: DS110DF111
Hi TI Team,
Could you please confirm whether retimer DS110DF111 supports SFP+ transceiver AFBR-710DMZ?
Or could you please suggest a SFP+ transceiver module supported by this retimer.
Hi TI Team,
Yes I believe AFBR-710DMZ should be compatible with DS110DF111 since it meets SFF-8431 electrical interface specifications.
Lucas
Thanks for replying Lucas!
Will this transceiver SFP+ DAC cable CAB-10GSFP-P0.5M-30 support DS110DF111?
Hi Sandra,
Yes I believe this cable will also be compatible with DS110DF111 since it is compliant with SFF-8431 electrical specifications. I'm assuming the retimer will exist on a line card between an ASIC/FPGA and an optical front port. Is this correct?
Are you interested in receiving the DS110DF111 IBIS-AMI model? This can be useful to confirm SFP+ eye mask requirements are met through simulation.
Lucas
Hi Lucas,
As you said the retimer IC comes between the Processor and SFP+ Connector.
We are also interested to receive the IBIS-AMI model for the retimer. Could you please do the needful.
Also could you please verify the SFP+ connector pinout.
Sandra
Hi Sandra,
Thank you for confirming your use case.
I sent you an E2E friend request. Please accept so I can share the IBIS-AMI model via E2E private message.
I cannot review your SFP+ connector network because it is not a TI part. I can review your DS110DF111 retimer schematic.
Lucas
