Part Number: DP83867E
For doing RGMII timing analysis of DP83867E(SNLS504D)
1.What is the setup and hold time required at PHY.
2.What is the difference between TsetupT and TsetupR in the fig 7-6. RGMII Receive Multiplexing and Timing Diagram
Timing guidelines are located in section 7.10 in datasheet. Please note that depending on configuration, PHY may have internal delay for RGMII which user may need to account for.
For the figure, the nomenclature may be inaccurate as the figure for 7-6 should only have R suffixes to denote the receiver, while T suffix denotes the transmitter.
Sincerely,
Gerome
