Part Number: TS3DV642-Q1
Hi Team,
Good day,
We are using TS3DV642-Q1 in our design to connect with Display port
We have following queries to be addressed by TI expert team.
- CEC pin can be left open or else recommended to use any Pullup/Pulldown
- HPD pin pulled down as per the datasheet recommendation
- Do we really needed AC coupling capacitors in series for all the differential pairs...If yes ,can you please confirm this (for Tx of Mux we have to place caps close to Mux side and for Rx side . caps should be placed to Serializer side/Debug port)
- Do we need Pull up in AUXP and pull down in AUXN Pins
We are using TS3DV642-Q1 in our design.
