SN65LVDT33: Maximum pulse and output skew
Part Number: SN65LVDT33
I'm performing a worst-case timing analysis.  Could you please provide maximum tsk(p) (Pulse skew) and maximum tsk(o) (Output skew)?  I see that only nominal values are presented in the current datasheet.
Thank you.
  • Hi Kimberlee,
    Looking at the device datasheet, you can see that the pulse skew was determined based on the propagation delay time, low-to-high-level output and propagation delay time, high-to-low-level output. These parameters do have min / max values, which would have been determined based on statistical data. This is why these values are not then again used to determine min / max values for pulse skew, and only a typical is quoted.
    This device is very old and the exact characterization data is not readily available, if it was taken.
    Regards, Amy
