Part Number: TUSB214
Dear TI Team:
we have 2 * TUSB214 in our design for USB 2.0 signal, pls help review the sch attached,
Best Regards
Lisa
Dear TI Team:
Best Regards
Lisa
Hi Lisa,
Here are my schematic reviews, please review the comments and let me know if there are any questions: TUSB214_Foxconn_NearCPU_SchemReview.pdf TUSB214_Foxconn_NearConnector_SchemReview.pdf .
Please let me know if you have any other questions.
Ryan
Hi Ryan:
Thanks for your review and feedback.and there is one item need you help.
1. Is RSTN being driven for both high and low, or just driven high when needed? If only being driven high when needed, should be okay.
==>we paln to have both high and low application for RSTN pin. So the sch need revise or not?
Best Regards
Lisa
Hi Lisa,
If the RSTN pin is being driven externally, you do not need to use an external capacitor. You only need to ensure that the RSTN pin is held low until the supply voltage reaches the specified minimum requirements of voltage.
If you want, you can leave the capacitor pulling down to ground. It should still be able to delay the power-on timing.
Ryan
Hi Ryan:
Hi Lisa,
A capacitor is recommended instead of a resistor.
Choose a capacitor value that has a ramp-time described in chapter 9 of the datasheet to make sure that RSTN is 5x longer than the VCC ramp-up time. [Ramp Time x 5] ÷ [500 kΩ]. So, even if CPLD is high at power-up, the device won't be enabled until 100us after Vcc is stable.
Nicholaus
Hi Nicholaus:
Thanks for your feedback and I will delete the 1K pull down resistor.
Best Regards
Lisa
Hi Nicholaus:
For power supply VCC design, whether need a bead between main power VCC_3V3 and TUSB214 VCC?
Best Regards
Lisa
Hi Lisa,
For the TUSB214, a ferrite bead should not be required. If there seems to be a large amount of noise in the power supply, it may be necessary, but as is, we do not have any requirements for a bead.
Ryan
