DP83826I: 10Base-T Pre-Compliance Test Issue
Part Number: DP83826I
Hi I am running pre-compliance test for 10Base-T and having issue for test :TP_IDL Template, with TPM (last bit CD0).
Link Test Pulse, with TPM is able to run and passed.
Settings: Ethernet Speed (10Base-T EEE)
Oscilloscope used: Keysight MSOS804A.
Test Fixture use: EEE-TPA-ER (P/N: 110-1089-000 REV.A)
Command use:
sendln 'phytool write eth1/0/0x001F 0x8000'
sendln 'phytool write eth1/0/0x0000 0x0100'
sendln 'phytool write eth1/0/0x0019 0x4021'
sendln 'phytool write eth1/0/0x0016 0x7101'
sendln 'phytool write eth1/0/0x000D 0x001F'
sendln 'phytool write eth1/0/0x000E 0x0469'
sendln 'phytool write eth1/0/0x000D 0x401F'
sendln 'phytool write eth1/0/0x000E 0x0555'
sendln 'phytool write eth1/0/0x001F 0x4000'
Attached the random data waveform.
Problem description: Whenever I run TP_IDL Template, with TPM (last bit CD0), the test aborted. System error and timeout error appeared in message.
p/s: All the test for 100BaseT is able to run and pass. No issue observed.
 10basev2.pdf
10 Base-Te, TP_IDL Template, with TPM (last bit CD0) was aborted. Details:
2024-04-01 11:39:17:927 AM  Error Performing Action on the scope
Error: timeout after issuing command: SYST:ERR? STR (Timeout=20000 ms)
Details:
In thread: ATE Run
Keysight.DigitalTestApps.Framework.AppUtils.Sicl+SiclIOException: timeout after issuing command: SYST:ERR? STR (Timeout=20000 ms) ---> Keysight.DigitalTestApps.Framework.AppUtils.Sicl+SiclIOTimeoutException: timeout after issuing command: SYST:ERR? STR
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.a(Int32 A_0, Boolean A_1)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.a(Int32 A_0)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.b(Int32 A_0, Int32 A_1, Int32& A_2, Byte[] A_3)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.ReadBinary(Int32 offset, Int32 size, Int32& actual, Byte[] output)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.ReadBinary(Int32 size, Boolean respectTimeoutMaximizers, Int32& actual)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.ReadBinary(Int32 size, Int32& actual)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.ReadInput()
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.a(IoArgs A_0)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.Query(IoArgs args)
   --- End of inner exception stack trace ---
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.Query(String query)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.CheckOutput(CheckIoArgs args)
   at Keysight.DigitalTestApps.Framework.AppUtils.Sicl.CheckOutput(String cmd)
   at Keysight.DigitalTestApps.Framework.TestSteps.Steps.EnhanceDynamicRangeStep.a(Sicl A_0, String A_1, String A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
   at Keysight.DigitalTestApps.Framework.TestSteps.Steps.EnhanceDynamicRangeStep.ImplementPerformStep()
Recent Action History:
[11:38:57.632]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 23.0181 ms
[11:38:57.634]CMD, :TRIG:ADV:PATTERN:LOGIC CHAN1, HIGH
[11:38:57.635]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1 ms
[11:38:57.636]CMD, :CHAN1:SCALE 500E-3
[11:38:57.854]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 218.8981 ms
[11:38:57.856]CMD, :ACQ:AVER OFF
[11:38:57.865]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 9.0064 ms
[11:38:57.875]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.876]CMD, :CHAN1:DISP ON
[11:38:57.876]CMD, :DIG
Detailed Action History:
[10:45:33.53]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 11.0063 ms
[10:45:33.54]CONNECT,
464.3105 ms
[10:45:33.57]QUERY, *IDN?
   <<KEYSIGHT TECHNOLOGIES,MSOS804A,MY63200106,06.74.00204
   Response Time: 0 ms
[10:45:33.64]QUERY, ATER?
   <<0
   Response Time: 4.003 ms
[10:45:33.168]CMD, :STOP
[10:45:33.195]QUERY, *IDN?
   Response Time: 26.8312 ms
[10:45:33.205]CMD, :DISK:SAVE:SETUP 'C:\ProgramData\Keysight\Infiniium\Apps\EthernetTest\pre.set'
[10:45:33.528]CMD, :STOP
[10:45:33.528]CMD, :CDIS
[10:45:33.528]CMD, :SYST:PRESET
[10:45:34.891]QUERY, *OPT?
   <<SDA,UDF,DEA,AER,ALT,ASV,DEB,BRR,BRP,BRS,BT1,CFD,CFU,CFL,CAN,C4C,C4S,DTS,MCP,XTK,XTU,C3P,D9010BDLP,D9010EXMA,D9110AUTP,D9010AUTP,D9110DMBA,D9010DMBA,D9110EKRP,D9010EKRP,D9110EMBP,D9010EMBP,D9110JITA,D9010JITA,D9110LSSP,D9010LSSP,D9110MCDP,D9010MCDP,D9110MILP,D9010MILP,D9110MPLP,D9010MPLP,D9110MPMP,D9010MPMP,D9110PAMA,D9110PCIP,D9010PCIP,D9110POWA,D9010POWA,D9110SCNA,D9010SCNA,D9110UDAA,D9010UDAA,D9110USBP,D9010USBP,D9120ASIA,D9020ASIA,D9120AUTP,D9020AUTP,D9120PAMA,D9010PAMA,DD4,DD5,AP2,D1S,DDR,D2D,D2S,DD3,D3D,D3S,D4S,DDB,DRF,DPT,D12,D13,13S,EDP,EDS,DPC,DPS,DPP,DVI,ECU,EEU,EMC,EEE,DEQ,ESP,EGT,E1C,E1K,EGR,E2S,E1S,ETN,EKC,EKR,EKS,TGS,ETH,E2M,NB2,E4C,E4S,E5M,NB5,ETP,EUS,EZC,UFS,HDM,H14,HTE,H1T,H2C,H21,H2T,HDS,HCS,HDF,HSI,HMC,ISP,I3C,EZJ,JTP,LLI,LSS,LP2,LP3,LP4,D4D,L4D,GMP,200,400,500,050,M3C,MHS,MPI,3PC,MCC,MDC,MDS,MDU,MP4,MMS,MPH,MPP,MHL,MST,MSS,MSO,MYC,B30,NRD,OD2,OSA,PM3,PM4,PCE,PEI,PEU,PFC,PIE,PI2,PIU,PSW,PCI,PC2,P3D,P4S,P4D,P5D,PEP,RXP,PES,PHN,PWI,PWR,PRN,RXT,CRI,RFE,EZP,RSP,SSS,STP,STS,SDC,SNT,SFP,QSS,SWT,SPW,SPP,SSC,SVD,EXT,TBS,UFP,UH2,UHS,UNI,U31,U3P,USS,U3S,USC,U4L,UPD,USP,RXU,UDS,VX1,FPG
   Response Time: 1361.0489 ms
[10:45:34.891]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[10:45:34.896]QUERY, :SYSTEM:DATA:VALUE? 'FRAM:VERS'
   <<1
   Response Time: 2.0014 ms
[10:45:35.421]QUERY, :HOST:ONL?
   <<1
   Response Time: 518.5891 ms
[10:45:35.427]QUERY, :ACQ:SRATE:TESTLIMITS?
   <<1,<numeric>1.0E+01:2.000E+10
   Response Time: 3.002 ms
[10:45:35.428]QUERY, :ACQ:BAND:TESTLIMITS?
   <<1,<numeric>5.0E+08:8.40E+09
   Response Time: 1.0023 ms
[10:45:35.433]QUERY, :CHAN1:SCAL:TESTLIMITS?
   <<1,<numeric>1.99E-03:9.95E+00
   Response Time: 3.0031 ms
   Response Time: 0 ms
[10:45:35.436]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 3.003 ms
[10:45:35.439]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 3.001 ms
[10:45:35.539]QUERY, ATER?
   <<1
   Response Time: 0.9993 ms
[10:45:35.545]CMD, :SYSTEM:SPECIAL?
[10:45:35.812]QUERY, :CHAN1:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>AUTO|OFF
   Response Time: 0 ms
[10:45:35.813]QUERY, :CHAN1:PROB:HEAD:SEL?
   Response Time: 1.0007 ms
[10:45:35.814]QUERY, :CHAN1:PROB:PREC:MODE:TESTLIMITS?
   <<1,<enum>PROBe
   Response Time: 1.0013 ms
[10:45:35.814]QUERY, :CHAN1:PROB:PREC:BAND:BOOST:TESTLIMITS?
   <<1,<numeric>3.0E+00:1.20E+01
   Response Time: 0 ms
[10:45:35.815]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   <<1,<numeric>1.84E+07:8.40E+09
   Response Time: 1.0003 ms
[10:45:35.815]QUERY, :CHAN1:PROB:PREC:MODE?
   <<PROB
   Response Time: 0 ms
[10:45:35.820]CMD, :CHAN1:PROB:PREC:MODE PROB
[10:45:35.823]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 2.001 ms
[10:45:35.825]QUERY, :CHAN1:PROB:PREC:CAL:TESTLIMITS?
   <<1,<string>"No Calibration Performed"
   Response Time: 0 ms
[10:45:35.825]CMD, :CHAN1:PROB:PREC:MODE PROB
[10:45:35.826]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.001 ms
[10:45:35.826]QUERY, :CHAN2:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[10:45:35.827]QUERY, :CHAN2:PROB:HEAD:SEL?
[10:45:35.827]QUERY, :CHAN2:PROB:PREC:MODE:TESTLIMITS?
   <<1,<enum>PROBe|CABLe
   Response Time: 0 ms
[10:45:35.827]QUERY, :CHAN2:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.827]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.827]QUERY, :CHAN2:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[10:45:35.827]CMD, :CHAN2:PROB:PREC:MODE PROB
[10:45:35.832]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 5.0027 ms
[10:45:35.832]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.832]CMD, :CHAN2:PROB:PREC:MODE CABL
[10:45:35.833]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.0041 ms
[10:45:35.833]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.833]CMD, :CHAN2:PROB:PREC:MODE CABL
[10:45:35.834]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[10:45:35.834]QUERY, :CHAN3:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[10:45:35.834]QUERY, :CHAN3:PROB:HEAD:SEL?
   Response Time: 0 ms
[10:45:35.835]QUERY, :CHAN3:PROB:PREC:MODE:TESTLIMITS?
[10:45:35.835]QUERY, :CHAN3:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.835]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.835]QUERY, :CHAN3:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[10:45:35.835]CMD, :CHAN3:PROB:PREC:MODE PROB
[10:45:35.845]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 10.0077 ms
[10:45:35.846]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.846]CMD, :CHAN3:PROB:PREC:MODE CABL
[10:45:35.847]QUERY, SYST:ERR? STR
   <<0,"No error"
[10:45:35.847]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.847]CMD, :CHAN3:PROB:PREC:MODE CABL
   <<0,"No error"
   Response Time: 0 ms
[10:45:35.847]QUERY, :CHAN4:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[10:45:35.847]QUERY, :CHAN4:PROB:HEAD:SEL?
   Response Time: 0 ms
[10:45:35.847]QUERY, :CHAN4:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.848]QUERY, :CHAN4:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0.9997 ms
[10:45:35.848]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.848]QUERY, :CHAN4:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[10:45:35.848]CMD, :CHAN4:PROB:PREC:MODE PROB
[10:45:35.849]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.0017 ms
[10:45:35.849]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.849]CMD, :CHAN4:PROB:PREC:MODE CABL
[10:45:35.852]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 3.0009 ms
[10:45:35.852]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[10:45:35.852]CMD, :CHAN4:PROB:PREC:MODE CABL
[10:45:35.853]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.0024 ms
[10:45:35.854]QUERY, *IDN?
[10:45:35.854]CMD, :FUNC:MATLAB:TERM "ETH";
[10:45:35.854]CMD, :FUNC:MATLAB:INIT "ETH";
[10:45:35.881]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.0006 ms
   <<0,"No error"
   Response Time: 0 ms
[10:45:35.910]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[10:45:37.93]CMD, :SYSTEM:SPECIAL?
[10:45:37.128]CMD, :SYSTEM:SPECIAL 0,0,0,0
[10:45:37.128]CMD, :SYSTEM:SPECIAL?
[10:45:37.144]CMD, :SYSTEM:SPECIAL 604634052,1925208962,163792452,1318576408
[10:45:37.160]CMD, :CHAN1:DISP OFF
[10:45:37.714]QUERY, :CHAN1:ISIM:PEXT?
   <<DIFF
   Response Time: 550.707 ms
[10:45:37.725]QUERY, :CHAN1:ISIM:BWL?
   <<0
   Response Time: 9.0057 ms
[10:45:37.726]QUERY, :CHAN1:ISIM:BAND?
   <<8.00E+09
   Response Time: 0 ms
[10:45:37.734]QUERY, :CHAN1:ISIM:SPAN?
   <<1.0000E-08
   Response Time: 7.0043 ms
[10:45:37.736]CMD, :CHAN1:ISIM:STAT PORT2
[10:45:37.988]QUERY, :CHAN1:ISIM:APPL?
   <<"C:\Users\Public\Documents\Infiniium\Filters\DoNothing.tf2"
   Response Time: 252.2215 ms
[10:45:37.988]CMD, :CHAN1:ISIM:STAT PORT4
[10:45:38.230]QUERY, :CHAN1:ISIM:APPL?
   <<"C:\Users\Public\Documents\Infiniium\Filters\DoNothing.tf4"
   Response Time: 242.1139 ms
[10:45:38.231]CMD, :CHAN1:ISIM:STAT Off
[10:45:38.431]QUERY, :CHAN1:ISIM:DEL?
   <<1
   Response Time: 199.5843 ms
[10:45:38.432]QUERY, :CHAN1:ISIM:BWLimit:TYPE?
   <<WALL
   Response Time: 0 ms
[10:45:38.433]QUERY, :CHAN1:ISIM:NORM?
   <<0
   Response Time: 0 ms
[10:45:38.434]QUERY, :CHAN1:ISIM:CORR?
   <<1.00E+02
   Response Time: 0 ms
[10:45:38.444]QUERY, :CHAN1:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>AUTO|OFF
   Response Time: 8.0163 ms
[10:45:38.445]QUERY, :CHAN2:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[10:45:38.446]QUERY, :CHAN3:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 1.0075 ms
[10:45:38.446]QUERY, :CHAN4:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[10:45:38.469]CMD, :SYSTEM:SPECIAL?
[10:45:38.484]CMD, :SYSTEM:SPECIAL 0,0,0,0
[10:45:39.590]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[10:45:39.591]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:43.785]QUERY, SYST:ERR? STR
   <<0,"No error"
   <<0,"No error"
   Response Time: 0 ms
[11:35:43.889]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.0014 ms
[11:35:43.895]CMD, :SYST:GUI 0
[11:35:44.697]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 801.6548 ms
[11:35:44.830]CMD, :STOP
[11:35:44.830]CMD, :CDIS
[11:35:44.830]CMD, :SYST:PRESET
[11:35:44.832]CMD, :DISK:SAVE:SETUP '%INF_USER_DATA_DIR%\RunStartedNoIsim.set'
[11:35:45.758]QUERY, :CHAN1:PROBe:INFO?
   <<N2752A, MY59364413, No Head, 29 MAR 2024 15:20:49, 1 JAN 1999 00:00:00, Cal Atten, Default Skew, 9.9506E+00, 1.0000E+00, 6.0000E+09
   Response Time: 922.0198 ms
[11:35:45.784]QUERY, :CHAN2:PROBe:INFO?
   <<No Probe, No Serial Num, No Head, 1 JAN 1999 00:00:00, 1 JAN 1999 00:00:00, Default Atten, Default Skew, 1.0000E+00, 1.0000E+00, 0.0000E+00
[11:35:45.784]QUERY, :CHAN3:PROBe:INFO?
   Response Time: 0 ms
[11:35:45.785]QUERY, :CHAN4:PROBe:INFO?
   <<User Defined Probe, No Serial Num, No Head, 1 JAN 1999 00:00:00, 1 JAN 1999 00:00:00, Default Atten, Default Skew, 1.0000E+00, 1.0000E+00, 0.0000E+00
[11:35:45.785]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.786]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 1.002 ms
[11:35:45.789]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 3.0126 ms
[11:35:45.790]QUERY, :CHAN1:SCAL:TESTLIMITS?
   Response Time: 0.9983 ms
[11:35:45.800]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 0.9986 ms
[11:35:45.802]QUERY, :CHAN1:ISIM:SPAN:TESTLIMITS?
   <<1,<numeric>1.875E-09:8.19150E-07
   Response Time: 1.0027 ms
[11:35:45.802]QUERY, :CHAN1:ISIM:CORR:TESTLIMITS?
   <<1,<numeric>0E+00:1.00E+02
   Response Time: 0 ms
[11:35:45.803]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
[11:35:45.803]QUERY, :CHAN2:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.804]QUERY, :CHAN2:ISIM:CORR:TESTLIMITS?
   Response Time: 1 ms
[11:35:45.804]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.805]QUERY, :CHAN3:ISIM:SPAN:TESTLIMITS?
[11:35:45.805]QUERY, :CHAN3:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.805]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.806]QUERY, :CHAN4:ISIM:SPAN:TESTLIMITS?
[11:35:45.806]QUERY, :CHAN4:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.810]CMD, :CHAN1:ISIM:STAT OFF
[11:35:45.810]CMD, :CHAN2:ISIM:STAT OFF
[11:35:45.810]CMD, :CHAN3:ISIM:STAT OFF
[11:35:45.810]CMD, :CHAN4:ISIM:STAT OFF
[11:35:45.811]QUERY, :CHAN1:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>AUTO|OFF
   Response Time: 0 ms
[11:35:45.813]QUERY, :CHAN1:PROB:HEAD:SEL?
   Response Time: 2.0024 ms
[11:35:45.814]QUERY, :CHAN1:PROB:PREC:MODE:TESTLIMITS?
   <<1,<enum>PROBe
   Response Time: 1 ms
[11:35:45.814]QUERY, :CHAN1:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.814]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.814]QUERY, :CHAN1:PROB:PREC:MODE?
   <<PROB
   Response Time: 0 ms
[11:35:45.814]CMD, :CHAN1:PROB:PREC:MODE PROB
[11:35:45.815]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.815]QUERY, :CHAN1:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.815]CMD, :CHAN1:PROB:PREC:MODE PROB
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.815]QUERY, :CHAN2:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:45.817]QUERY, :CHAN2:PROB:HEAD:SEL?
[11:35:45.817]QUERY, :CHAN2:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.817]QUERY, :CHAN2:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.817]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.818]QUERY, :CHAN2:PROB:PREC:MODE?
   <<CABL
[11:35:45.818]CMD, :CHAN2:PROB:PREC:MODE PROB
[11:35:45.820]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 2.0017 ms
[11:35:45.820]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.820]CMD, :CHAN2:PROB:PREC:MODE CABL
[11:35:45.821]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.821]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.821]CMD, :CHAN2:PROB:PREC:MODE CABL
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.821]QUERY, :CHAN3:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:45.823]QUERY, :CHAN3:PROB:HEAD:SEL?
[11:35:45.824]QUERY, :CHAN3:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0.9999 ms
[11:35:45.824]QUERY, :CHAN3:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.824]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.824]QUERY, :CHAN3:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:35:45.824]CMD, :CHAN3:PROB:PREC:MODE PROB
[11:35:45.827]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.827]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:45.827]CMD, :CHAN3:PROB:PREC:MODE CABL
[11:35:45.829]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 2.0021 ms
[11:35:45.830]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0.9996 ms
[11:35:45.830]CMD, :CHAN3:PROB:PREC:MODE CABL
[11:35:45.830]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.830]QUERY, :CHAN4:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:45.832]QUERY, :CHAN4:PROB:HEAD:SEL?
[11:35:45.848]QUERY, :CHAN4:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 16.0103 ms
[11:35:45.858]QUERY, :CHAN4:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 9.942 ms
[11:35:45.859]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 1.0031 ms
[11:35:45.859]QUERY, :CHAN4:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:35:45.859]CMD, :CHAN4:PROB:PREC:MODE PROB
[11:35:45.860]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.861]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
[11:35:45.861]CMD, :CHAN4:PROB:PREC:MODE CABL
[11:35:45.864]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 3.0037 ms
[11:35:45.867]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
[11:35:45.867]CMD, :CHAN4:PROB:PREC:MODE CABL
[11:35:45.868]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.874]CMD, :CHAN1:PROB:ACCAL Auto
[11:35:45.875]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:45.875]CMD, :CHAN2:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.875]CMD, :CHAN3:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.876]CMD, :CHAN4:PROB:ACCAL Off
[11:35:45.876]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:45.878]CMD, :DISK:SAVE:SETUP '%INF_USER_DATA_DIR%\RunStarted.set'
[11:35:45.879]CMD, :CHAN1:PROBe:STYPe DIFFerential
[11:35:46.54]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 175.1175 ms
[11:35:46.56]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.57]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:46.117]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.159]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.162]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.166]QUERY, SYST:ERR? STR
   <<0,"No error"
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.170]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.191]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:46.826]CMD, :DISK:LOAD '%INF_USER_DATA_DIR%\RunStarted.set'
[11:35:47.32]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 197.1325 ms
[11:35:47.32]QUERY, :CHAN1:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.34]QUERY, :CHAN1:ISIM:CORR:TESTLIMITS?
   Response Time: 2.0006 ms
[11:35:47.34]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.34]QUERY, :CHAN2:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.34]QUERY, :CHAN2:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.35]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
[11:35:47.35]QUERY, :CHAN3:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.35]QUERY, :CHAN3:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.35]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.35]QUERY, :CHAN4:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.35]QUERY, :CHAN4:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.36]CMD, :CHAN1:ISIM:STAT OFF
[11:35:47.36]CMD, :CHAN2:ISIM:STAT OFF
[11:35:47.36]CMD, :CHAN3:ISIM:STAT OFF
[11:35:47.36]CMD, :CHAN4:ISIM:STAT OFF
[11:35:47.36]QUERY, :CHAN1:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>AUTO|OFF
   Response Time: 0 ms
[11:35:47.39]QUERY, :CHAN1:PROB:HEAD:SEL?
[11:35:47.39]QUERY, :CHAN1:PROB:PREC:MODE:TESTLIMITS?
   <<1,<enum>PROBe
   Response Time: 0 ms
[11:35:47.39]QUERY, :CHAN1:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.39]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.40]QUERY, :CHAN1:PROB:PREC:MODE?
   <<PROB
[11:35:47.40]CMD, :CHAN1:PROB:PREC:MODE PROB
[11:35:47.40]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.40]QUERY, :CHAN1:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.40]QUERY, :CHAN2:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:47.42]QUERY, :CHAN2:PROB:HEAD:SEL?
[11:35:47.42]QUERY, :CHAN2:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.42]QUERY, :CHAN2:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.43]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
[11:35:47.43]QUERY, :CHAN2:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:35:47.43]CMD, :CHAN2:PROB:PREC:MODE PROB
[11:35:47.45]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:47.45]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.45]CMD, :CHAN2:PROB:PREC:MODE CABL
[11:35:47.48]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 3.0023 ms
[11:35:47.48]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.49]CMD, :CHAN2:PROB:PREC:MODE CABL
[11:35:47.49]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.50]QUERY, :CHAN3:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:47.51]QUERY, :CHAN3:PROB:HEAD:SEL?
[11:35:47.69]QUERY, :CHAN3:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 18.011 ms
[11:35:47.70]QUERY, :CHAN3:PROB:PREC:BAND:BOOST:TESTLIMITS?
[11:35:47.70]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.70]QUERY, :CHAN3:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:35:47.70]CMD, :CHAN3:PROB:PREC:MODE PROB
[11:35:47.71]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:47.72]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 1 ms
[11:35:47.72]CMD, :CHAN3:PROB:PREC:MODE CABL
[11:35:47.75]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:47.76]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
[11:35:47.76]CMD, :CHAN3:PROB:PREC:MODE CABL
[11:35:47.76]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.76]QUERY, :CHAN4:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:35:47.79]QUERY, :CHAN4:PROB:HEAD:SEL?
   Response Time: 3.0027 ms
[11:35:47.79]QUERY, :CHAN4:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.80]QUERY, :CHAN4:PROB:PREC:BAND:BOOST:TESTLIMITS?
[11:35:47.81]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
[11:35:47.81]QUERY, :CHAN4:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:35:47.81]CMD, :CHAN4:PROB:PREC:MODE PROB
[11:35:47.83]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1.9993 ms
[11:35:47.91]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 8.0618 ms
[11:35:47.91]CMD, :CHAN4:PROB:PREC:MODE CABL
[11:35:47.92]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:47.92]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:35:47.92]CMD, :CHAN4:PROB:PREC:MODE CABL
[11:35:47.93]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:35:47.93]CMD, :CHAN1:PROB:ACCAL Auto
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.93]CMD, :CHAN2:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.94]CMD, :CHAN3:PROB:ACCAL Off
[11:35:47.94]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.94]CMD, :CHAN4:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:35:47.103]CMD, :AUT
[11:35:55.150]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 8046.3862 ms
   ~!!! Long Action !!!~
[11:35:55.152]CMD, :BUS:B1:TYPE GEN
[11:35:56.408]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 1255.8376 ms
[11:35:56.429]CMD, :DISK:LOAD '%INF_USER_DATA_DIR%\RunStarted.set'
[11:38:53.894]CMD, :CHAN1:DISP OFF
[11:38:54.274]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 380.0721 ms
[11:38:54.276]CMD, :CHAN1:DISP ON
[11:38:54.672]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 396.6955 ms
[11:38:54.690]CMD, :SYSTEM:PRESET
[11:38:55.417]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 726.616 ms
[11:38:55.418]CMD, :STOP
[11:38:55.501]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 82.7236 ms
[11:38:55.501]CMD, :CDIS
[11:38:55.509]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 8.0128 ms
[11:38:55.509]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:55.509]CMD, :CHAN1:DISP OFF
[11:38:56.244]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 734.9204 ms
[11:38:56.244]CMD, :CHAN2:DISP OFF
[11:38:56.247]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.247]CMD, :CHAN3:DISP OFF
[11:38:56.248]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.248]CMD, :CHAN4:DISP OFF
[11:38:56.249]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.249]CMD, :FUNC1:DISP OFF
[11:38:56.250]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0.999 ms
[11:38:56.250]CMD, :FUNC2:DISP OFF
[11:38:56.290]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 40.1063 ms
[11:38:56.290]CMD, :FUNC3:DISP OFF
[11:38:56.291]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.291]CMD, :FUNC4:DISP OFF
[11:38:56.292]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.292]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.292]CMD, :CHAN1:DISP ON
[11:38:56.673]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 381.3366 ms
[11:38:56.673]CMD, :CHAN1:OFFS 0.0E+00
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.673]CMD, :CHAN1:SCALE 1.0E+00
[11:38:56.699]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 25.0071 ms
[11:38:56.699]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.699]CMD,
[11:38:56.700]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.700]CMD, :TIM:SCALE 200.00E-09
[11:38:56.708]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 7.0026 ms
[11:38:56.708]CMD, :TIM:POS 0.0E+00
[11:38:56.717]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 9.006 ms
[11:38:56.717]CMD, :TIM:REF CENTER
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.717]CMD, :TRIG:SWEEP AUTO
[11:38:56.718]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.718]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.718]CMD, :TRIG:HYSTERESIS HSENSITIVITY
[11:38:56.719]QUERY, SYST:ERR? STR
   <<25,"This entry isn't a valid selection. The control has not been modified."
   Response Time: 1.0021 ms
[11:38:56.720]CMD, :TRIG:LEVEL CHAN1, 250E-3
[11:38:56.723]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 3.0024 ms
[11:38:56.723]CMD, :TRIG:HOLD 80.0E-9
[11:38:56.725]QUERY, SYST:ERR? STR
   <<-222,"Data out of range"
   Response Time: 2.003 ms
[11:38:56.725]CMD, :TRIG:MODE ADV
[11:38:56.794]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 69.1736 ms
[11:38:56.794]CMD, :TRIG:ADV:MODE PATTERN
[11:38:56.803]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.804]CMD, :TRIG:ADV:PATTERN:CONDITION RANGE, 200E-9, 600E-9
[11:38:56.876]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 72.0463 ms
[11:38:56.877]CMD, :TRIG:ADV:PATTERN:THRESHOLD:LEVEL CHAN1, 250E-3
[11:38:56.878]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.879]CMD, :TRIG:ADV:PATTERN:LOGIC CHAN1, HIGH
[11:38:56.964]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 84.1155 ms
[11:38:56.965]CMD, :TRIG:HYSTERESIS HSENSITIVITY
[11:38:56.970]QUERY, SYST:ERR? STR
   Response Time: 5.0287 ms
[11:38:56.970]CMD, :ACQ:AVER OFF
[11:38:56.973]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.973]CMD, :RUN
[11:38:56.976]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.976]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.976]CMD,
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.976]CMD,
[11:38:56.977]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:56.977]CMD,
   <<0,"No error"
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:38:56.980]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.981]QUERY, :CHAN1:ISIM:SPAN:TESTLIMITS?
[11:38:56.984]QUERY, :CHAN1:ISIM:CORR:TESTLIMITS?
[11:38:56.984]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.984]QUERY, :CHAN2:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.985]QUERY, :CHAN2:ISIM:CORR:TESTLIMITS?
[11:38:56.985]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.985]QUERY, :CHAN3:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.985]QUERY, :CHAN3:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.987]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 2.0023 ms
[11:38:56.987]QUERY, :CHAN4:ISIM:SPAN:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.987]QUERY, :CHAN4:ISIM:CORR:TESTLIMITS?
   Response Time: 0 ms
[11:38:56.988]CMD, :CHAN1:ISIM:STAT OFF
[11:38:56.988]CMD, :CHAN2:ISIM:STAT OFF
[11:38:56.988]CMD, :CHAN3:ISIM:STAT OFF
[11:38:56.988]CMD, :CHAN4:ISIM:STAT OFF
[11:38:56.993]QUERY, :CHAN1:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>AUTO|OFF
   Response Time: 5.0026 ms
[11:38:56.996]QUERY, :CHAN1:PROB:HEAD:SEL?
[11:38:56.997]QUERY, :CHAN1:PROB:PREC:MODE:TESTLIMITS?
   <<1,<enum>PROBe
[11:38:57.7]QUERY, :CHAN1:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 9.0047 ms
[11:38:57.7]QUERY, :CHAN1:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.7]QUERY, :CHAN1:PROB:PREC:MODE?
   <<PROB
   Response Time: 0 ms
[11:38:57.7]CMD, :CHAN1:PROB:PREC:MODE PROB
[11:38:57.7]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.7]QUERY, :CHAN1:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.8]QUERY, :CHAN2:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
[11:38:57.9]QUERY, :CHAN2:PROB:HEAD:SEL?
[11:38:57.9]QUERY, :CHAN2:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.9]QUERY, :CHAN2:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.9]QUERY, :CHAN2:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.9]QUERY, :CHAN2:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:38:57.9]CMD, :CHAN2:PROB:PREC:MODE PROB
[11:38:57.13]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 4.0023 ms
[11:38:57.14]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
[11:38:57.14]CMD, :CHAN2:PROB:PREC:MODE CABL
[11:38:57.14]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.15]QUERY, :CHAN2:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 1 ms
[11:38:57.15]CMD, :CHAN2:PROB:PREC:MODE CABL
[11:38:57.15]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.15]QUERY, :CHAN3:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
   Response Time: 0 ms
[11:38:57.15]QUERY, :CHAN3:PROB:HEAD:SEL?
   Response Time: 0 ms
[11:38:57.15]QUERY, :CHAN3:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.16]QUERY, :CHAN3:PROB:PREC:BAND:BOOST:TESTLIMITS?
[11:38:57.16]QUERY, :CHAN3:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.16]QUERY, :CHAN3:PROB:PREC:MODE?
   <<CABL
   Response Time: 0 ms
[11:38:57.16]CMD, :CHAN3:PROB:PREC:MODE PROB
[11:38:57.21]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 5.0043 ms
[11:38:57.32]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 11.0649 ms
[11:38:57.32]CMD, :CHAN3:PROB:PREC:MODE CABL
[11:38:57.35]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:57.35]QUERY, :CHAN3:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.35]CMD, :CHAN3:PROB:PREC:MODE CABL
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.36]QUERY, :CHAN4:PROB:ACCAL:TESTLIMITS?
   <<1,<enum>OFF
[11:38:57.36]QUERY, :CHAN4:PROB:HEAD:SEL?
   Response Time: 0 ms
[11:38:57.36]QUERY, :CHAN4:PROB:PREC:MODE:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.36]QUERY, :CHAN4:PROB:PREC:BAND:BOOST:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.36]QUERY, :CHAN4:ISIM:BAND:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.37]QUERY, :CHAN4:PROB:PREC:MODE?
   <<CABL
[11:38:57.37]CMD, :CHAN4:PROB:PREC:MODE PROB
[11:38:57.37]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.37]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.37]CMD, :CHAN4:PROB:PREC:MODE CABL
[11:38:57.38]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:57.38]QUERY, :CHAN4:PROB:PREC:CAL:TESTLIMITS?
   Response Time: 0 ms
[11:38:57.38]CMD, :CHAN4:PROB:PREC:MODE CABL
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.39]CMD, :CHAN1:PROB:ACCAL Auto
[11:38:57.39]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.39]CMD, :CHAN2:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.39]CMD, :CHAN3:PROB:ACCAL Off
[11:38:57.40]QUERY, SYST:ERR? STR
   <<0,"No error"
[11:38:57.40]CMD, :CHAN4:PROB:ACCAL Off
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.49]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 0 ms
[11:38:57.49]CMD, :TRIG:SWEEP TRIG
[11:38:57.49]CMD, :DIG;
[11:38:57.131]QUERY, *OPC?
   <<1
   Response Time: 82.1706 ms
[11:38:57.131]CMD, :STOP
[11:38:57.147]QUERY, :ACQ:BAND:FRAM?
   <<8.000E+09
   Response Time: 10.0926 ms
[11:38:57.147]CMD, :ACQ:BANDWIDTH 1000000000
[11:38:57.150]CMD, :ACQ:SRATE 2E9
[11:38:57.551]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 401.5358 ms
[11:38:57.554]CMD, :TRIG:SWEEP TRIG
[11:38:57.578]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 24.015 ms
[11:38:57.580]CMD, :TRIG:MODE ADV
[11:38:57.601]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 21.0151 ms
[11:38:57.603]CMD, :TRIG:ADV:MODE PATTERN
[11:38:57.606]QUERY, SYST:ERR? STR
   <<0,"No error"
   Response Time: 2.0297 ms
[11:38:57.609]CMD, :TRIG:ADV:PATTERN:THRESHOLD:LEVEL CHAN1, 200E-3
   <<0,"No error"
   <<0,"No error"
   Response Time: 1 ms
   <<0,"No error"
   <<0,"No error"
   <<0,"No error"
   Response Time: 0 ms
  • Hi Prakash,
    The register configuration and waveform looks good to me, it's possible the issue is with the scope software/configuration.
    Are you able to reach out to Keysight to check this error log and confirm if this issue is on scope or PHY end?
    Also, do you see any difference when setting 0x19 = 0x21 rather than 0x4021?
    Thank you,
    Evan
