Part Number: TUSB321
Hi, Support Team
We will use TUSB321, schematic as below chart. have any concern?
if any suggestion, Please advise me.
Lawrence
Hi, Support Team
Lawrence
Hi Lawrence,
I see you're operating in DFP mode, but I don't see how you control your VBUS switch. This is typically done with the ID pin from the TUSB321.
How do you enable/disable the VBUS on the type-C port?
Shane
Hi, Shane
We use TPS2065CDGNR as Type-C Vbus switch, please refer the picture below.
Lawrence
Hi Lawrence,
I see the SOC is controlling the VBUS switch, but what logic does it use to enable/disable the switch?
This is the purpose of the ID pin on the TUSB321. The VBUS switch should be enabled when ID is low, and disabled when ID is high. USB-C requires that VBUS is not enabled until after the CC negotiation is finished on the CC controller.
I drew a diagram to help show this connection:
Shane
Hi Lawrence,
I hope you're doing well. Were you able to look at my question from earlier?
If you no longer need support, I'll mark this as resolved.
Shane
