Part Number: DS36277
Other Parts Discussed in Thread: THVD1550
Is there any alternate part available for DS36276M/NOPB ?
Amit Gade
Hi Amit,
What is the max data rate you need to support?
From what I can see, the DS36277 part seems like it works with the RS485 standard so you should be able to use an RS485 transceiver.
The recommended part from the product folder shows THVD1550. Can you take a look at that part and see if it meets your requirements? If you need to support higher common mode voltage or ESD/Surge, let me know and we can look into some other suggestions.
-Bobby
