Part Number: TCAN1167-Q1
Hello team,
Normally the 5V LDO can output up to 100mA, but we noticed the description in datasheet: When a CAN bus fault takes place that requires additional current from the LDO, the total available current to external load components may be degraded.
So I want to the lowest external supply current, and does the 100mA refer to internal LDO current or external Vccout current?
Cause customer need to use this power rail to supply for MCU, the worst Vccout current is important.
Thanks.
